Author Topic: Handicap mode Daytona USA Arcade  (Read 2125 times)
tangodownNZ
  • Last login:September 29, 2025, 05:07:04 am
« on: November 26, 2022, 03:02:32 am »
In Daytona if you press the four view buttons at the track select screen, a little white dot will appear in the top left of your screen. This enables tire wear and disables catch up/handicap mode (which allows all cars behind the leader to catch up). You basically need to pit every couple of laps to keep your car from spinning out because the tires wear out way too fast. But disabling the handicap mode is great. If there was a way to disable handicap but not have tire wear. Imagine how much better this would make the game. Somebody like Nuexzz could probably do this
« Last Edit: November 28, 2022, 02:12:07 am by tangodownNZ »
