Author Topic: SKJukebox in Windows 10  (Read 4186 times)
cdburnerr
  • Last login:November 11, 2022, 02:29:42 pm
« on: November 11, 2022, 02:25:36 pm »
Hello,
I just installed SK Jukebox on a Windows 10 machine, and when I try to run it, I get the following error:
Component 'imagXpr6.dll' or one of it's dependencies not correctly registered. A file is missing or invalid.
Any ideas? There is a imagXpr6.dll file in the SK Jukebox folder...
Rebel Oz 69
  • Last login:February 15, 2026, 08:21:57 pm
  • Old-school arcade fan.
Re: SKJukebox in Windows 10
« Reply #1 on: November 11, 2022, 10:46:54 pm »
I had the same problem, both with Windows 7 & Windows 10.
The Fix:
1. Open up a command prompt (CMD), with Administrator privilege.
2. CD to where you've installed SK Jukebox. EG:
cd C:\Program Files (x86)\SK Jukebox
3. Register the DLL manually with Windows:
regsvr32 ImagXpr6.dll
4. You may then find it complains about  MSCOMCTL.OCX.
regsvr32 MSCOMCTL.OCX will resolve that. :)
