Author Topic: groovy->mame-hbmame-wolfmame b4nd1to's builds (nonag/cv1k/others)  (Read 93651 times)
0 Members and 10 Guests are viewing this topic.
DreyMIX
  • Last login:May 10, 2024, 01:28:11 pm
Re: groovy->mame-hbmame-wolfmame b4nd1to's builds (nonag/cv1k/others)
« Reply #80 on: February 02, 2024, 12:11:46 pm »
Hi @b4nd1t0,
I'm looking for the groovywolf 0.183 for linux, but without success. I saw groovywolf 0.183 on your repository, but unfortunately I noticed that you had compiled it only for windows. Would it be possible for you to compile it for the Linux system too? (I generally use Ubuntu, I don't know if it makes a difference).
But if you can't do it, can you tell me the system to be able to compile for me the version I'm looking for? What exactly do I need? I've never compiled a version of MAME, so tell me if it's complicated.
Thank you!
to compile 183 you need GCC 5.3.0, with the wolfmame sources you apply the groovy patch 017c, check for any errors (with --dry-run) and make any necessary changes
So with difficulty I finally managed to compile groovywolfmame 0.183. The groovy patch 0.17c, I managed to find it on a MEGA repository.
I had to try several old ubuntu dists. I started from 14.04.4 and got up to 16.10 where I uninstalled g++-6 and gcc-6 and downloaded the respective previous versions from the apt, i.e. version 5. In reality he gave me 5.4, but he didn't given compilation problems. I just had to recreate the g++-5 and gcc-5 symlinks as g++ and gcc (/usr/lib/). Then at a certain point it gave me a "linux_x64" compilation error, I looked for the problem on the internet and all I had to do was open the "makefile" file and change the line "QT_HOME = /usr/lib64/qt48/" to "QT_HOME = / usr/lib/x86_64-linux-gnu/qt5/".
In the end he created the mame64 executable file for me
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
« Reply #81 on: February 02, 2024, 01:33:59 pm »
groovyhbmame 0.245.16 win/linux ready
seems switchres is disabled. If i enable it in the ini groovyhbmame won't start. any ideas?
b4nd1t0
  • Last login:January 29, 2026, 03:45:54 am
    • b4nd1t0's repository
« Reply #82 on: February 06, 2024, 03:54:13 am »
I haven't tried it sincerely, generally if I don't have compilation errors, it's ok for me.
What version are you trying and what errors does it give you?
androtaz08
« Reply #83 on: February 06, 2024, 08:19:49 pm »
here are the logs.
b4nd1t0
« Reply #84 on: February 08, 2024, 06:58:24 am »
new version, tried to apply only the groovy patch, test it
androtaz08
« Reply #85 on: February 08, 2024, 12:45:19 pm »
same result. though the google drive doesn't look like its the updated version you mentioned.
b4nd1t0
« Reply #86 on: February 08, 2024, 01:40:10 pm »
it wasn't on the drive but on the telegram group, however we did some tests and the problem remains, so I think I will no longer compile hbmame with the groovy patch
androtaz08
« Reply #87 on: February 08, 2024, 01:48:12 pm »
aww man that's a shame. I love your builds. There's always great street fighter and mortal kombat clones every month id hate not to be able to check them out without the use of switches
b4nd1t0
« Reply #88 on: March 11, 2024, 11:30:49 am »
Hi everyone, here I am with the latest updates, I finally managed to make the disabled cave games work on linux only by compiling a specific version for the cv1k driver, so if you want to play with those titles and the groovy 0.263 - Switchres 2.220a you will have to use 2 separate executables.
You can find them in the usual place.
Trnzaddict
  • Last login:September 21, 2025, 10:48:29 am
« Reply #89 on: April 04, 2024, 02:22:55 pm »
Hi b4nd1t0,
Whenever I launch a Neo Geo title, It launches but I get an error warning about Driver Karnovr.ccp (4 errors, 0 warnings) non sequential bios blah blah blah.
Any ideas?
b4nd1t0
« Reply #90 on: April 05, 2024, 03:09:39 am »
tried now with metal slug, no problem, are you sure the romset is correct?
Below is the log.
Attempting load of mame.ini
Parsing mame.ini
Parsing mame.ini
Attempting load of horizont.ini
Attempting load of raster.ini
Parsing raster.ini
Attempting load of source\neogeo.ini
Attempting load of neogeo.ini
Attempting load of mslug.ini
Starting plugin data...
Starting plugin hiscore...
Starting plugin layout...
Parsing mame.ini
Parsing mame.ini
Parsing raster.ini
Video: Monitor 65539 = "\\.\DISPLAY1"
Video: Monitor 65537 = "\\.\DISPLAY4" (primary)
Direct3D: Using Direct3D 9
Physical width 1265, height 976
Direct3D: Initialize
Direct3D: Configuring adapter #1 = Intel(R) UHD Graphics 630
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Input: Adding keyboard #1: HID Keyboard Device (device id: \\?\HID#WmVirtualDevice#2&37214c1c&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding keyboard #2: HID Keyboard Device (device id: \\?\HID#VID_046D&PID_C232#2&5480ef7&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding keyboard #3: HID Keyboard Device (device id: \\?\HID#VID_2516&PID_012F&MI_02&Col03#7&372746dc&0&0002#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding keyboard #4: HID Keyboard Device (device id: \\?\HID#VID_046D&PID_C534&MI_00#7&5018ca2&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #1: HID-compliant mouse (device id: \\?\HID#VID_2516&PID_012F&MI_00#7&9f4a992&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #2: HID-compliant mouse (device id: \\?\HID#VID_046D&PID_C534&MI_01&Col01#7&1831a8e0&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #3: HID-compliant mouse (device id: \\?\HID#WmVirtualDevice#2&24679b77&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #1: HID-compliant mouse (device id: \\?\HID#VID_2516&PID_012F&MI_00#7&9f4a992&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #2: HID-compliant mouse (device id: \\?\HID#VID_046D&PID_C534&MI_01&Col01#7&1831a8e0&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #3: HID-compliant mouse (device id: \\?\HID#WmVirtualDevice#2&24679b77&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
unzip: opened archive file roms\mslug.zip
unzip: found roms\mslug.zip ECD at 980
unzip: roms\mslug.zip has no ZIP64 ECD locator
unzip: read roms\mslug.zip central directory
unzip: closing archive file roms\mslug.zip and sending to cache
unzip: found roms\mslug.zip in cache
unzip: opened archive file roms\neogeo.zip
unzip: found roms\neogeo.zip ECD at 980
unzip: roms\neogeo.zip has no ZIP64 ECD locator
unzip: read roms\neogeo.zip central directory
unzip: closing archive file roms\neogeo.zip and sending to cache
unzip: found roms\neogeo.zip in cache
Optional device ':cslot6' not found
Optional device ':cslot5' not found
Optional device ':cslot4' not found
Optional device ':cslot3' not found
Optional device ':cslot2' not found
Optional memory region ':audiocpu' not found
Optional memory region ':fixed' not found
Optional memory region ':sprites' not found
Optional shared pointer ':maincpu' not found
Optional memory region ':maincpu' not found
Optional memory region ':screen' not found
Optional memory region ':ymsnd:adpcmb' not found
Optional memory region ':ymsnd:adpcma' not found
Optional memory region ':saveram' not found
Optional memory region ':cslot1:ymsnd:adpcmb' not found
Optional memory region ':cslot1:audiocrypt' not found
Starting Metal Slug - Super Vehicle-001 ':'
  (missing dependencies; rescheduling)
Starting Motorola MC68000 ':maincpu'
Starting Zilog Z80 ':audiocpu'
Starting 74HC259 Addressable Latch ':systemlatch'
Starting Video Screen ':screen'
Starting palette ':palette'
Starting Neo-Geo Sprites (optimized) ':spritegen'
Starting Input Merger (all high) ':audionmi'
Starting Generic 8-bit latch ':soundlatch'
Starting Generic 8-bit latch ':soundlatch2'
Starting YM2610 OPNB ':ymsnd'
Starting Watchdog Timer ':watchdog'
Starting uPD4990A RTC ':upd4990a'
Starting NVRAM ':saveram'
Starting Speaker ':lspeaker'
Starting Speaker ':rspeaker'
Starting NeoGeo Memory Card ':memcard'
Starting SNK Neo Geo Edge Connector (Controller) ':edge'
Starting SNK Neo Geo Arcade Joystick ':edge:joy'
Starting SNK Neo Geo controller port ':ctrl1'
Starting SNK Neo Geo controller port ':ctrl2'
Starting Neo Geo Cartridge Slot ':cslot1'
Starting Neo Geo Standard Carts ':cslot1:rom'
Attempting to parse: default.cfg
Attempting to parse: mslug.cfg
Direct3D: YUV format = UYVY
Direct3D: Max texture size = 8192x8192
Direct3D: Device created at 1249x937
Direct3D: Initialize HLSL
Direct3D: First store options
Direct3D: HLSL initialized
Average speed: 100.00% (16 seconds)
b4nd1t0
« Reply #91 on: April 05, 2024, 09:10:39 am »
Hi b4nd1t0,
Any ideas?
in the 0264 i have the error, the game start but i have two black bars, i think, the problem is the neogeo patch, I'll do some tests
UPDATE: fixed
« Last Edit: April 05, 2024, 10:22:21 am by b4nd1t0 »
suverman
« Reply #92 on: April 21, 2024, 01:27:39 am »
Thanks for the builds b4nd1to, any chance to have a more recent groovy build for HBMAME? Thank you very much.
b4nd1t0
« Reply #93 on: November 21, 2024, 06:39:18 am »
« Last Edit: November 21, 2024, 06:54:55 am by b4nd1t0 »
reeone
  • Last login:August 20, 2025, 01:53:28 am
« Reply #94 on: November 21, 2024, 07:14:54 am »
can't lauch groovyhbmame_0245.21.002k_b4n_build_win,if switchres    1
can lauch with switchres    0
but only as a hbmame
arcadeswede
  • Last login:February 15, 2025, 10:03:44 am
    • Revansch!
« Reply #95 on: February 10, 2025, 08:52:42 am »
@b4nd1t0 Are you able to compile GroovyArcade with hiscore and cv1k fix?
Nevermind, I figured it out!
But! Where the heck do I find no nag patches for latest mame 0.274? I would like to no nag my compiled build.
« Last Edit: February 15, 2025, 10:04:01 am by arcadeswede »
schmerzkaufen
« Reply #96 on: April 16, 2025, 09:46:43 am »
Heya b4nd1t0, I keep using your variant of the build, though I'd be thrilled about a fresh GroovyCave if you feel like it one of those days  ;) cya  8)
shinobi68
  • Last login:November 29, 2025, 04:32:25 pm
« Reply #97 on: November 19, 2025, 05:32:25 pm »
Hi,
Could someone share the latest working version of Groovy HBMame? Thanks for your incredible work.
