Author Topic: Hacking TV EEPROM  (Read 2969 times)
Zebidee
  • Last login:Yesterday at 08:46:22 pm
Hacking TV EEPROM
« on: September 19, 2022, 10:37:50 am »
So, after fixing a dodgy EEPROM on one of my TVs (by swapping in a know good EEPROM IC from another TV), I decided having an EEPROM burner would be nice for making replacements.
I found this ridiculously cheap USB EEPROM burner for about US$6-8. I also got a 10 blank EEPROMS (24C08, DIP-8 packages) for a similar cost.
Then I desoldered the EEPROM from my main testing TV (component modded), dumped it, edited the data slightly (logo), put it back in...
Now I have a GreenAntz TV!
Irony is, you only see this new logo when the TV is NOT receiving any input from the GreenAntz!
My small amusement for the evening :D
« Last Edit: September 19, 2022, 10:52:55 pm by Zebidee »
bobbyb13
  • Last login:November 19, 2025, 03:12:34 am
Re: Hacking TV EEPROM
« Reply #1 on: September 19, 2022, 02:11:19 pm »
That's fun.
More fascinating stuf I'm still clueless about!
  • Last login:November 19, 2025, 06:31:36 pm
« Reply #2 on: September 19, 2022, 06:01:13 pm »
I use the ch341 to reprogram bios's on motherboards that fail to boot. quite often the chip goes bad causing it. download a new bios, and dump it on... bam! up and going again.
i've rescued 4 or 5 boards from this now.
neoprogrammer is the software i use. seems to work pretty good.
Zebidee
« Reply #3 on: September 19, 2022, 09:48:25 pm »
@lilshawn
Thanks for the neoprogrammer tip! You really are a wealth of information :D
It seems to have been updated more recently, and seems to support a wider range of chips.
Development links are dead, but other download links are out there.
I used some generic Chinese software (recommended by seller) dating back to 2004. Works well enough, but it only supports the 24XXX and 25XXX series of chips.
You have to "Run as administrator", otherwise it won't work (and won't be able to quit either, needed to use Task Manager to end task).
You also need to install the driver first (comes with software) and put the "english.ini" file into "languages" folder (why it isn't there to begin with, I cannot say).
Original development links for this are long dead too.
If you are interested, you can download it here:
https://github.com/KrisKasprzak/CH341
This video of how to use the CH341A + software is essential viewing:
Good "tool" to have in your kit.
@Bobby
You'd be fine once you got your brain around it. None of it is rocket science. You are a wizard at the carpentry/painting/craft stuff. Play to your strengths.
That thought in mind, I always find it hard to change "modes", like from carpentry/painting/craft stuff to programming/electronics/wiring stuff. It is almost like I have to lift a flap on my skull and move a switch in my brain. I'd say it gets worse as I get older, but when I was younger I didn't know ---steaming pile of meadow muffin---, so comparisons would be pointless :D
Can we reset the switch?
  • Last login:Today at 09:07:35 am
« Reply #4 on: September 19, 2022, 09:56:39 pm »
Why are your pants halfway down your legs in that reflection?
« Reply #5 on: September 19, 2022, 09:58:48 pm »
HAHAHAHAHAHAHAHAHA  :laugh2:
 :censored:
Zebidee
« Reply #6 on: September 19, 2022, 10:21:16 pm »
:lol is actually a towel. I was aware of reflections and wearing short-shorts, didn't want anyone feeling jealous :D
Zebidee
« Reply #7 on: September 19, 2022, 10:54:29 pm »
Substituted a more modest pic to save pbj further embarrasssment ;)
