Author Topic: Wheel2XInput, designed for mapping wheel and wheel accessories to XInput  (Read 47745 times)
nugarp
  • Last login:October 23, 2025, 11:12:59 pm
Re: Wheel2XInput, designed for mapping wheel and wheel accessories to XInput
« Reply #40 on: October 23, 2025, 11:11:30 pm »
Hello, I understand you can use multiple inputs and assign them in Wheel2XInput. I see an example for overriding one GUID with another for say a specific button but here's what I'm trying to accomplish...
I have a TMX racing wheel and the TH8S shifter. I want to map the shifter to currently mapped dpad and paddles on the wheel in the json, not override it, but have both inputs working. How would I code that into the json? I have used the trace app to pull the GUID and button numbers, so just need to know how to inject that info into the json.
Map multiple inputs to the same output, it will work as you want by default as I assume these are digital inputs and not analog that you are making as your targets.
Another way to say this: you can have the same targetButtons or targetDpads for multiple defined inputs.
Wheel2XInput | HDRecoil | LeaderLamps | NetLauncher | Discord | Youtube
