Author Topic: Unable to connect to desired wireless network using GASetup  (Read 1678 times)
GroggyExpulsion
  • Last login:July 15, 2025, 05:39:43 pm
« on: September 07, 2022, 05:15:55 pm »
When using the built in GASetup utility and the network setup utility, there is a mismatch between the listed SSID's and the actual the SSID chosen when entering the matching password.
For example the list of available SSID's will be
SSID 1
SSID 2
SSID 3
My desired network is SSID 3 which i will choose, on the next screen, it will tell me i am actually trying to connect to SSID 4, and the list SSID 1-3 also do not match when selecting them to enter passwords, it makes it impossible to connect to my desired network.
Is there a config file somewhere that i can manually edit to choose my preferred network?
nb, i have run the built in updater, and everything is up to date
« Last Edit: September 07, 2022, 05:47:15 pm by GroggyExpulsion »
Substring
  • Last login:Today at 09:29:53 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Re: Unable to connect to desired wireless network using GASetup
« Reply #1 on: September 07, 2022, 06:13:06 pm »
Nop config file, and I've just configured a WiFi network where i Had a dozen possible, had no problem although I didn't check if the selected SSID was the right one.  but it worked, really.
Manual wifi connection requires iwd commands IIRC, I may check if you need
GroggyExpulsion
« Reply #2 on: September 08, 2022, 03:39:24 pm »
That's ok, i should be able to figure out IWD.
It's a weird one though, it's like all the listed SSID's are out of sync with the actual network names when i select them. Not a show stopped as i have ethernet run across my garage floor at the moment.
GroggyExpulsion
« Reply #3 on: September 14, 2022, 03:14:04 pm »
IWD did the trick, cheers
