Author Topic: GRS Tron Joystick question  (Read 1119 times)
Scotty
  • Last login:May 01, 2025, 09:16:56 am
« on: August 30, 2022, 08:21:37 pm »
OK, So I have the Tron stick and spinner from Glen's Retro Show.  Both work great.  Problem is the stick is a little shorter than the original arcade machine.  I noticed Arcadeshop.com sells an arcade replacement stick CHEAP.  Just the shell though, not the actual base of the stick.    Has anyone tried the ArcadeShop stick on the GRS base?  Does it fit??
https://www.arcadeshop.com/i/1735/tron-joystick-handle-kit.htm
