Author Topic: Filter 31khz signal  (Read 1765 times)
iori01
  • Last login:May 18, 2024, 05:41:12 pm
Filter 31khz signal
« on: August 16, 2022, 05:31:21 am »
Hi all,
While transforming my Blast cabinet to 31khz only, I have now a PC with a multi front-end.
Problem I have is boot sequence, where monitor get lots of different frequencies other than 31k before being on desktop.
I'm looking for a solution to protect the screen like Jammasd is doing and let only 31k passthrough.
Do you have an idea to acheive this ?
Can't use Atom since card is Nvidia, can't boot the PC before the cabinet because JVS is not powered and then not recognized.
Any idea is welcome 😊
buttersoft
  • Last login:Yesterday at 06:06:35 pm
  • Is running at 15kHz
Re: Filter 31khz signal
« Reply #1 on: August 16, 2022, 07:27:45 pm »
I think a J-pac will let you filter for 31kHz. Possibly 31kHz and below, but that might do it?
Or you can take a look at Gambaman's code for his Ultimate SCART adapter. I could never it to compile right, but the lines for the frequency band are in there, and you could probably make it output separate sync. Hmm, the more i go on the more complicated it seems, but possibly worth a look?
http://forum.arcadecontrols.com/index.php/topic,160869.0.html
iori01
« Reply #2 on: August 29, 2022, 05:34:23 pm »
Thanks for this proposal, this is exactly what I was looking for.
But in the meantime I've found a workaround to change the Graphic Card to an AMD R9 2XX , hence I've flashed BIOS with Atom (31 only) and voila !
Thanks again for your help.
