Author Topic: Grooveymame running on wrong monitor - switchres popup  (Read 1617 times)
licehead
  • Last login:December 07, 2023, 08:15:16 pm
« on: August 10, 2022, 07:55:04 pm »
Got grooveymame running on CRT for the first time the other night. Moved my setup around to incorporate a main lcd monitor to better navigate windows and have the crt as the 2nd monitor. Now when I launch mame it only appears on the lcd monitor and the pop "Switchres:could not find a video mode that meets your specs" shows up. I messed with the mame ini file to change screen to \\.\DISPLAY1 (tried 2 and 3 as well, no change). Uploaded my mame ini file. I'm sure it's a simple fix and I'm just missing something but I'm stumped.
abispac
  • Last login:Today at 11:07:20 am
Re: Grooveymame running on wrong monitor - switchres popup
« Reply #1 on: August 11, 2022, 02:07:24 am »
you need to run mame in verbose mode -v to find what number mame adds to your monitor, in my case was \\.\DISPLAY8 , so adding \\.\DISPLAY8 to it solved my problem.
makya
  • Last login:December 16, 2025, 10:25:53 am
« Reply #2 on: August 12, 2022, 10:30:26 am »
Hello, you should put 2 in front of numscreens in your ini file.
