Author Topic: Crt emudriver resolutions from modelines all shifted to the right a bit  (Read 1590 times)
apeezyfosheezy
  • Last login:August 09, 2022, 01:59:53 am
Hi there,
I’m having an issue installing modelines during crt emudriver setup. Every resolution I try seems to be shifted over to the right a slight amount (maybe 10 pixels or so at least and black to the left of where it shifts). Is there any way to fix those? Do I need to edit the modelines? I’m trying to run 2560x240p.
I am using a crt standard definition rear projection tv. It is being output from hdmi to component (using a portta hdmi to component converter) into the tv. i am using an ATI hd 5450.
Is the issue the fact that I’m using hdmi output? The reason I’m not using vga is my pv and tv are in separate rooms with an hdmi running through the wall between them. Would using the VGA port make any difference?
psakhis
  • Last login:September 24, 2024, 11:54:25 am
Re: Crt emudriver resolutions from modelines all shifted to the right a bit
« Reply #1 on: August 09, 2022, 03:25:10 pm »
Hi,
Are you tried arcadeOSD.exe builtin on crt emudrivers?
If you can center image with this tool, you can edit crt_range properly.
