Author Topic: Screen cutoff horizontally left and right  (Read 2492 times)
Pengo2040
  • Last login:August 16, 2022, 08:12:03 pm
« on: August 06, 2022, 11:49:22 pm »
I use groovymame on a CRT on an old Emachines T3422. it works great but cuts off a significant portion of the screen both left and right. The TV's service menu only allows vertical adjustment. is there anything I can do other than using mames sliders?
Pengo2040
Re: Screen cutoff horizontally left and right
« Reply #1 on: August 06, 2022, 11:56:15 pm »
Tv is a ct27d10b I believe (the sticker fell off long ago)
psakhis
  • Last login:September 24, 2024, 11:54:25 am
« Reply #2 on: August 07, 2022, 03:28:21 am »
You need to edit custom crt_range on mame.ini, for that a very good tool is arcadeOSD
@Calamity very soon release a GM version with sliders for adjust geometry, this help you a lot.
Pengo2040
« Reply #3 on: August 07, 2022, 05:10:29 am »
how do I adjust? is there a guide somewhere?
psakhis
« Reply #4 on: August 07, 2022, 06:14:31 am »
For horizontal resize, you need modify h front porch, hsync and h back porch on crt_range0 from mame.ini
crt_range0  15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 448, 576
If you are in Windows, with crt emudriver you have a tool arcadeOSD that help you know these values.
Recapnation
  • Last login:May 16, 2025, 07:59:16 am
    • Eiusdemmodi
« Reply #5 on: August 07, 2022, 06:50:32 am »
Oh. What did I miss?
Pengo2040
« Reply #6 on: August 07, 2022, 08:05:19 am »
also since I was using mames sliders i turned off the switchres way back and dont know how to turn it back on I'm pretty sure I set everything right in mame.ini but not seeing scanlines. any help would be apreciated
Pengo2040
« Reply #7 on: August 07, 2022, 05:29:58 pm »
After 5ish years I managed to actually get it with supermodes, instead of cutting of the screen it just shifted now, no problem my tv menu does have horizontal position. now it only cuts off a tiny bit on each side, fraction of a letter comperable to actual arcade cabs ive seen.
psakhis
« Reply #8 on: August 09, 2022, 04:28:55 am »
Try GM 0.246 with new geometry options.
