Author Topic: Happ Trackball Help  (Read 1419 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
Happ Trackball Help
« on: March 01, 2004, 09:03:11 am »
I am thinking of buying a used 3" Happ trackball from a friend. How do I connect this to my computer? Do I need an Optipac or something similar?
nipsmg
  • Last login:December 02, 2025, 01:18:04 pm
  • ROONEY!! ERRGH!!
    • Arcadia
Re:Happ Trackball Help
« Reply #1 on: March 01, 2004, 09:14:35 am »
Your best bet is an OptiPac.  Easy installation (take the wires, connect them to the board with screw-down terminals, plug in, GO!.
--NipsMG
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
« Reply #2 on: March 01, 2004, 11:29:39 am »
Optipac, or a mouse hack.
Do a search on this. Even I, with remedial soldering skills, was able to pull it off in about 1.5 hrs.
$5 PS2 mouse
$3 solder and molex connector for the Shack.
I could probably do one now in 30 minutes.
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #3 on: March 01, 2004, 11:41:00 am »
True you can do it cheaper, but my personal opinion is, go for the optipac.  You're buying a solution you KNOW works, and you now have an interface for a spinner, or even 2 spinners, and one more trackball if you wanted to.
Note: If you get an optipac, and you don't have an Ipac, get the Optipac USB version.  It draws its power from the USB port  Otherwise you have to get +5 and gnd to the optipac another way.
--NipsMG
Stingray
« Reply #4 on: March 01, 2004, 11:50:09 am »
Just fyi for the original poster, you can get +5 & gnd off your computer's power supply.
-S
