Author Topic: Coin door light questions  (Read 3940 times)
codeena
  • Last login:December 03, 2023, 06:23:54 pm
  • This site is cool
« on: July 24, 2022, 08:17:20 pm »
Hi, I wired a 4.5V AC power adapter to light up my two coin door's 6.3V lamps. It seems to work fine but I wanted to confirm that this is safe, which I assumed since the AC adapter has less voltage. If so, how many 6.3 lamps can I daisy chain to a single AC adapter? I have an additional 3 lighted buttons on the control panel that I'd like to light up as well. P.S. I don't want to power them to the PC's power supply for several reasons.
Thanks in advance!
  • Last login:Today at 09:15:18 am
Re: Coin door light questions
« Reply #1 on: July 25, 2022, 12:32:22 am »
Yes, it is safe to run 6.3VAC lamps on 4.5VAC as long as you don't wire too many in parallel which will draw too many Amps.
Two important questions:
1. How many Amps is the power supply rated for?
2. What kind of lamps are you trying to light?  (T3-1/4 wedge base or bayonet base?  LEDs?  Incandescent #44, #47, or #555?)
- Many incandescent bulbs draw 150mA (#47) or 250mA (#44 or #555), regular LEDs usually only draw 20mA, and some surface mount LEDs draw 50mA.
codeena
  • This site is cool
« Reply #2 on: July 25, 2022, 02:20:59 am »
Scott,
Thanks yet again for your time and reply. The power supply has an Input of 120V 60Hz 6W and Output of 4.5V DC 300mA.
Each coin door bulb is #555 wedge base but I haven't opened the control panel up yet because I'm looking for the security bits.
thank u
« Last Edit: July 25, 2022, 10:16:23 am by codeena »
« Reply #3 on: July 25, 2022, 10:24:11 am »
Each coin door bulb is #555 but I haven't opened the control panel up yet because I'm looking for the security bits.
With that power supply you can run one incandescent #555 bulb.
Swap the incandescent #555 bulbs for 5v or 12v T3-1/4 wedge base LEDs.
  • Last login:Today at 09:33:22 am
« Reply #4 on: July 25, 2022, 10:33:38 am »
Just use some LEDs.  Problem solved.
codeena
  • This site is cool
« Reply #5 on: July 25, 2022, 04:03:32 pm »
Thanks for the reply. I actually have a bunch of #555 non-LED bulbs that I'd like to use first unless there would be a problem lighting all five bulbs with one or two power adapters. If 6.3V or equivalent LED bulbs are used, can I use a single power adapter?
Another question if anyone could help...I'm having issues pulling out the bulbs in this illuminated pushbutton. It doesn't seem to rotate to release like other light buttons I have or pull straight out. Any ideas how to access the bulbs?
« Reply #6 on: July 25, 2022, 04:10:03 pm »
I have similar buttons.  Just pull harder, they'll come out.  I've had to use pliers before to get a tight enough grip.
« Reply #7 on: July 25, 2022, 07:27:01 pm »
The problem would be that the 4.5VDC 300mA power supply you described can't handle the current draw for more than one non-LED #555 bulb because they draw 250mA each.
Best case, if the coin door has two non-LED #555s and the three buttons have 12v LEDs, they're drawing about 518mA.
- (250mA * 2) + (6mA * 3) = 518mA
Worst case, if all five lamps are non-LED #555s, they're drawing about 1250mA and the buttons on the control panel are roasting your fingers.   >:D
- 250mA * 5 = 1250mA
LEDs are your friend.
Paradise Arcade Shop has these LED #555 replacements for the coin door (won't fit in some pushbuttons) and white or red or blue or green LEDs for the pushbuttons.
- These LEDs will run on that 300mA power supply with no problem.   ;D
On most illuminated buttons, the body of the button has tabs that fit into slots on the bulb socket/switch holder.
1. Put the switch back in so the arms are less likely to flex/break.
2. Rock the socket/switch holder as you try to turn it.
The rock/turn trick should work for tab/slot buttons (round) or peg/slot buttons. (triangle)
If your socket is a snap-in like the rectangular one below, wiggle the socket in a conical motion whle pulling and gently twisting.
« Reply #8 on: July 27, 2022, 12:22:11 am »
I prefer to use only leds at this point.   Not only are they typically brighter but they help to preserve your stuff.   When certain plastics are heated they become brittle and/or discolored over time.   Using leds eliminates this problem.
codeena
  • This site is cool
« Reply #9 on: July 28, 2022, 09:41:39 pm »
Ordered some LED bulbs. Thanks all!
