Author Topic: What to use to seal a button hole.  (Read 3931 times)
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
« on: June 22, 2022, 04:43:51 pm »
Hi. should I use putty, glue or bondo to seal up an arcade button hole so I can move the button to another location. Thanks.
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
thomas_surles
Re: What to use to seal a button hole.
« Reply #1 on: June 22, 2022, 05:55:26 pm »
What kind of material is the panel? If it's wood you could use a hole saw bit the size of the button holes and cut out a piece from scrap glue in the hole. Then wood putty over it and sand it down. I've personally gotten by with just wood filler globbed in there then sanded flat.
  • Last login:Today at 06:46:54 am
« Reply #2 on: June 22, 2022, 11:24:06 pm »
Oh man. I read the thread title wrong.
My advice won't apply.
jdbailey1206
« Reply #3 on: August 17, 2022, 06:30:06 pm »
Or will it?  Ortiz didnt say how long it needed to be filled……
