Author Topic: Hantarex polo/2 side of screen squashed  (Read 5002 times)
Harlock
  • Last login:January 12, 2023, 10:35:54 am
« on: May 12, 2022, 07:24:11 am »
Hi, I bought an arcade cabinet lately and it came with a 25'' inch crt with a Hantarex polo/2 25-28 chassis.
My issue is tha the image is kinda squassed in the far right side and a bit in the far left side (attachements for example) , I tried to play abit with the horizontal position and size pots it didn't help,
what else should I try? Try to change caps? should I find a replacement (someone on ebay said that "MOTRAX 1570 Moniteur Chassis 25-28 " is a compatible
replacement)? Is there a setting on the chassis board that I am missing, there are some extra pots that I am not sure what they do but they are not labeled.
Thanks in advance.
grantspain
Re: Hantarex polo/2 side of screen squashed
« Reply #1 on: May 12, 2022, 12:36:50 pm »
maybe someone messed with the linearity coil, which is a adjustable
princess prin prin
  • Last login:Yesterday at 11:28:07 am
  • intrinsically safe
« Reply #2 on: May 13, 2022, 01:43:55 pm »
Bad linearity at the sides vs middle is due to a wrong value of the s-correction cap. If it's a 15KHz chassis the s-cap is C97 behind the flyback transformer. If the value of this cap is lower than it should, the sides get more squashed than in the middle. If the chassis is running with the original tube, check the value of C97 and if it has gotten much lower than the nominal value, replace it with one of the same value. If the chassis has been mated to a different tube and the value of C97 is good, replace the cap with a higher value one (e.g. 470nF ---> 560nF or 680nF).
If it's a 15-25KHz chassis, there are two more s-caps on the switch board (the small vertical board under the power supply cage) that are put in series with C97 depending on the selected frequency (C4 for 15KHz and C6 for 25KHz). If the issue happens only at one frequency you need to check the value of the cap relevant to that frequency. Once the issue is mostly fixed (vertical lines are equidistant on the left side and in the middle but slightly more squashed on the right side), you need to adjust (rotate) the magnet at the base of the linearity coil (L11) with a custom plastic tool that you can make yourself (just don't use a metal one).
Harlock
« Reply #3 on: May 16, 2022, 06:36:12 am »
 If I am not mistaken, my chassis is a 31khz since it outputs SVGA, although I thing this is the card you are mentioning (first picture), do those pots do anything? or should I just go ahead and start to changing caps? I can't be sure but it seems like monitor/cabin/chassis are all the original pair. Crt doesn't have any stickers on it though.
Btw, I played around with the linearity coil and it didn't fix anything (black thingy next to fan).
princess prin prin
« Reply #4 on: May 16, 2022, 08:23:22 am »
OK, you have the VGA/SVGA version (31KHz and higher). The sticker says the chassis is made for a Philips A59EAK552X44 tube (25"). The yokes on Philips tubes have a characteristic design that can't be confused with that of other manufacturers. If it looks like this it's a Philips, if not post a pic.
You'll have to remove the fan to see C97. It's not an electrolytic cap, it looks like a little box. The blue square is where the caps on the frequency switch board are and the red square is the linearity coil. It can be adjusted by turning the magnet at the bottom.
« Last Edit: May 16, 2022, 08:25:09 am by princess prin prin »
Harlock
« Reply #5 on: May 16, 2022, 09:05:39 am »
I created a tool and played a bit with the linearity coil you showed me, tried turning it both ways but it just shrinked the whole image horizontally. My monitor for sure it's not like the one you showed me btw.
What should I do now? change the C97? to the same cap value (film capasitor 0.18uf/400V)? try anything else? Thanks again for your help.
princess prin prin
« Reply #6 on: May 16, 2022, 10:42:11 am »
That's a Panasonic tube so we can't be sure the value of C97 is correct for it. If you have a capacitance tester measure it and see if it has decreased a lot. Alternatively, get a few caps of increasing value and try them until the sides are as wide as the middle (a vertical bar test pattern is more helpful than in-game pictures). Try: 0.18, 0.27, 0.36, 0.47 (depending on where you buy them, the value could be in nanofarad so 180, 270, etc.). It's important that the voltage rating is the same (400V) and also the lead spacing (22.5 mm).
Harlock
« Reply #7 on: May 16, 2022, 11:35:00 am »
Thanks a ton, I will give a try and come back at you
Harlock
« Reply #8 on: May 20, 2022, 09:07:15 am »
Hey, I think It worked, although previous capacitor was fine, I bought some mkt capacitors (Actually it needed mkp, but I made a mistake and bought mkt ones although mkt worked for testing), I soldered some posts in order to try different ones, 0,366nF and some width twiking seems to do the trick.
It still has some slite weird quirks, like for example 2-3 brigther lines at the far left but they are hardly noticeable, the result is soooo much better than before and I really thank you that you helped, you are a true wizard in this area.
The only alarming thing I noticed through testing is that with larger C97 capacitor, the capacitor is getting hotter (yes it is rated for 400v) with using pandora box vga output, but it gets like A LOT hotter when I use a vga output from a laptop or a GBS-8200 (cga to vga converter). Although if I solder it on the proper side of the chassis it is almost under tha fan so it will help.
Also I think I created a tiny bending on the sides when I was testing linearity coil setting that can't get rid of with cushion pot, I will fix it probably with some more tweeking.
But overall it I am much happier with the result than before, I can't even grasp how you knew about the specific capacitor.  :applaud:
princess prin prin
« Reply #9 on: May 20, 2022, 01:16:40 pm »
Check the solder joints of R142 in parallel with the linearity coil. It's a fact that without that resistor you get a jailbar/ringing effect at the left side. As it's pretty tall maybe it got knocked when you adjusted the coil?
Not sure but I suggest to improve the solder joints of the 4-pin green header that connects C97 to the frequency switch board. Also, I see a lot of dust build up around the horizontal output transistor T22 that you better blow off to make it run cooler.
Other monitors have this cap too so if you have the same issue you know what to look for.
Harlock
« Reply #10 on: May 30, 2022, 05:23:09 am »
I am not sure, if I have pulled anything will I was wokring on it, but now there is some kind of interference in the screen, small waves in the whole screen. I used to make them go away by moving the board a bit
while trying to undestand what it was loose, I resolder some cables on the board and now is permenent :( . It seems more like a grounding issue, the board is grounded on earth though.
« Last Edit: May 30, 2022, 06:45:59 am by Harlock »
Harlock
« Reply #11 on: May 30, 2022, 09:42:28 am »
After some experimentation I am pretty sure that the psu creates this interference, if I hook the vga to a laptop the interference goes away. Not sure why is that and why it now started to be happening.
Still haven't figured out what is happening with the curvy sides :(
What else will go wrong with this crappy arcade?
grantspain
« Reply #12 on: June 02, 2022, 02:43:58 am »
what is the tube number?
there are components that need matching to the tube type
Harlock
« Reply #13 on: June 06, 2022, 09:26:59 am »
If I read the correct number, 68SP110H29 and after a square with a circle it sais 54.
grantspain
« Reply #14 on: June 06, 2022, 11:49:29 am »
i was expecting something like A66EAK501X
anyway there is a resistor on the vertical size circuit and if it dont match the tube then you can adjust side pin but it never goes quite right, in conjunction with little vertical size adjustment
the resistor is R119 and it should be a 1r2 or 0.82, if you have 0.82 then replace with a 1r2 and vice versa
there is also a resistor on the east/west pcb that needs to be checked R9, on some tubes it needs to be removed and others it needs to be 39k
maybe this info will be of some help
Harlock
« Reply #15 on: June 08, 2022, 04:31:21 am »
I didn't have any issue with vertical sizing only horizontal, should I still try changing R9 and R119?
grantspain
« Reply #16 on: June 11, 2022, 05:35:35 am »
ok polostar so ignore my previous post, the heading of polo 2 confused me
