Author Topic: New hardware for groovymame 243  (Read 2296 times)
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« on: May 03, 2022, 02:50:50 pm »
So, after couple years of my cab hardware with Intel Pentium G3258 I finally upgraded to groovymame version 243. Sadly some games do not run so good as years ago due added discrete sound emulation, emulation improvements that usually cost in performance. I was thinking of rather cheap replacement. So far I have two candidates Intel Pentium G7400 (I read it can be overclocked just like G3258 in the past and it has impressive performance after that), i3-12100F (another cheap option and again can be overclocked using BCLK frequency).
Are there any other cheap options ? This is my cab PC used for only emulation. I don't know how MAME these days uses multicore processors so maybe someone could enlighten in this matter. For several years G3258 with just two cores did a great job. Of course it also matter of changing mainboard, RAM as well :/
« Last Edit: May 03, 2022, 03:05:06 pm by haynor666 »
haynor666
  • retro maniac
Re: New hardware for groovymame 243
« Reply #1 on: May 25, 2022, 03:29:23 am »
Well, it appears that changing hardware does not make sense for me - only couple of games works now below 100% (mostly due net list analog audio) when I compare to older mame versions. Spending another 200 USD would be waste of money.
Maxforwardspeed
  • Last login:April 06, 2023, 08:27:02 am
« Reply #2 on: May 25, 2022, 07:48:46 pm »
I'm in a similar boat... currently have AMD A-10 3.5 Ghz quad core, but it struggles with a few of the 3D games. I was thinking about updating MAME and my romset, but not sure it would be worth the hassle and cost since I would probably need a faster CPU, main board, RAM, and power supply . Looks like I'll be sticking with my older version of MAME so I don't get any further performance hits!
haynor666
  • retro maniac
« Reply #3 on: May 26, 2022, 08:22:18 am »
I don't know what version You are using but jumping from 210 to 243 for me was ok. Most of games still works fine. Personally I don't bother 3D games (with exception of some shmups like Brave Blade).
