Author Topic: Vectorising an arcade game: VectorKong is Completed  (Read 23602 times)
10yard
  • Last login:March 06, 2026, 08:21:35 am
  • L BREAK into program
    • DKAFE Frontend
« on: April 15, 2022, 11:48:28 am »
Part 1: Vectorising the background (see below)
Part 2: Vectorising the character/fonts ( link to post )
Part 3a: Vectorising some of the sprites ( link to post )
Part 3b: Vectorising Kong's sprites ( link to post )
Part 3c: Vectorising Jumpman's sprites ( link to post )
Part 4: Adding a title screen and finishing things off ( link to post )
I'm having a go at vectorising Donkey Kong for MAME.  I'll be hacking the original game,  suppressing the normal pixel output completely and rendering high resolution vectors to the screen.  The techniques i'll be  using could be applied to other classic arcade games.  I'm choosing Donkey Kong because i'm very familiar with the disassembled code and mechanics of the game.
I'm documenting my journey and hopefully you may find it interesting and follow along.
I took inspiration from this blog which considers if a Donkey Kong port would be feasible on the Vectrex.
http://vide.malban.de/november-21st-donkey-kong-wait-no
My plan is to use the simple vector drawing capabilities of MAME LUA scripting language (available in MAME from version 0.196 to current).
There are some limitations.  All vectors must be drawn out every frame and there are 60 frames per second.  Optimisation is key and i'll have to do some calculations before I get carried away.  I'll work out how many vectors can be safely drawn each frame without compromising the emulation speed.
First we'll need to write some LUA code to instantiate the emulated screen device in MAME so we can draw to it.
scr = manager.machine.screens[":screen"]
Then we'll need a simple function to draw a vector.  This function draws a line from x,y position to another x,y position.  Anything we draw,  including other shapes,  will me made up of vectors and will use this function.
function vector(y1, x1, y2, x2)
scr:draw_line(y1+wobble(), x1+wobble(), y2+wobble(), x2+wobble(), intensity())
vector_count = vector_count + 1
end
We'll keep tally of the number of vectors we draw.
Notice the funky "wobble" and "intensity" options.  These are used to make vectors appear less boring on screen.
We can make a polyline function to draw multiple vectors that are chained together like etch-a-sketch
function polyline(data)
-- draw multiple chained lines from a table of x, y data points
local _y, _x
for _i=1, #data, 2 do
if _y and _x then vector(data[_i], data[_i+1], _y, _x) end
_y, _x =data[_i], data[_i+1]
end
end
We can make a function to draw a box by chaining 4 lines with our polyline function.  We can specify the height and width of the box.
function box(y, x, h, w)
-- draw a simple box at given position with height and width
polyline({y,x,y+h,x,y+h,x+w,y,x+w,y,x})
end
We can make a function to draw a circle by chaining lots of vectors together.  I ran with 20 vectors per circle.
function circle(y, x, r)
-- draw a 20 segment circle at given position with radius
local _save_segy, _save_segx
for _segment=0, 360, 18 do
local _angle = _segment * (math.pi / 180)
local _segy, _segx = y + r * math.sin(_angle), x + r * math.cos(_angle)
if _save_segy then vector(_save_segy, _save_segx, _segy, _segx) end
_save_segy, _save_segx = _segy, _segx
end
end
We now have our 4 drawing functions so lets try to max out MAME to see how many vectors we can draw per frame.
I made a function for testing the limits.  This function will cycle through 4 different drawing tests (lines, polylines, boxes and circles).  We can increase the limit gradually and keep a check on MAME average emulation speed (Function key F11).
function debug_limits(limit)
local _rnd, _ins = math.random, table.insert
local _cycle = math.floor(scr:frame_number() % 720 / 180)  -- cycle through the 4 tests, each 3 seconds long
if _cycle == 0 then
for _=1, limit do vector(256, 224, _rnd(248), _rnd(224)) end  -- single vectors
elseif _cycle == 1 then
_d={}; for _=0,limit do _ins(_d,_rnd(256)); _ins(_d,_rnd(224)) end; polyline(_d)  -- polylines
elseif _cycle == 2 then
for _=1, limit/20 do circle(_rnd(200)+24, _rnd(176)+24, _rnd(16)+8) end  -- circles
else
for _=1, limit / 4 do box(_rnd(216), _rnd(200), _rnd(32)+8, _rnd(24)+8) end  -- boxes
end
debug_vector_count()
end
Results show we can safely draw 1000 vectors per frame when tested in MAME versions 0.196 and 0.242 running on Windows 10 at 1920x1080. Reducing the resolution increases the limit.  1200 per frame is ok too but let's keep it safely inside the limits.  I'll also test on Raspberry Pi 4 later.
This video shows our tests running on top of Donkey Kong attract mode.
I think 1000 vectors should be sufficient.  I'll use vectors sparingly and keep tally of the numbers as I progress.
Let's start by building background graphics for the girders stage.  Here are functions to draw girders and ladders.
A simple girder is made from 2 parallel lines.  We can add detail later if our vector count allows.
function draw_girder(y1, x1, y2, x2)
-- draw parallel vectors (offset by 7 pixels) to form a girder.  Co-ordinates relate to the bottom vector.
vector(y1,   x1,   y2, x2, intensity())
vector(y1+7, x1, y2+7, x2, intensity())
end
A ladder is a more complex object with legs and rungs.  We'll need to deal with broken ladders too.  We can treat broken ladders as 2 separate ladders that are set slightly apart.
function draw_ladder(y, x, h)
-- draw a single ladder at given y, x position of given height in pixels
vector(y, x,   y+h, x)  -- left leg
vector(y, x+8, y+h, x+8)  -- right leg
for i=0, h-2 do  -- draw rung every 4th pixel (skipping 2 pixels at bottom)
if i % 4 == 0 then vector(y+i+2, x, y+i+2, x+8) end
end
end
We now test drawing girders and ladders.  In total we have used 139 vectors.
Now for some other background detail for the girders stage.  The oilcan, hammers and the stacked barrels.
function draw_oilcan(y, x)
box(y,     x,  1,  16)  -- outline of oil can
box(y+1, x+1, 14,  14)  -- bottom lip
box(y+15,  x,  1,  16)  -- top lip
box(y+7,   x+4,  3,   3)  -- "O"
vector(y+7, x+9, y+10, x+9)  -- "I"
polyline({y+7,x+13,y+7,x+11,y+10,x+11})  -- "L"
vector(y+5, x+1, y+5, x+15)  -- horizontal stripe
vector(y+12, x+1, y+12, x+15)  -- horizontal stripe
end
function draw_hammer(y, x)
polyline({y+5,x,y+7,x,y+8,x+1,y+8,x+8,y+7,x+9,y+5,x+9,y+4,x+8,y+4,x+1,y+5,x})  -- hammer
box(y,   x+4, 4, 1)  -- bottom handle
box(y+8, x+4, 1, 1)  -- top handle
end
function draw_barrel(y, x)
-- draw an upright/stacked barrel
polyline({y+3,x,y+12,x,y+15,x+2,y+15,x+7,y+12,x+9,y+3,x+9,y,x+7,y,x+7,y,x+2,y+3,x})  -- barrel outline
vector(y+1,  x+1, y+1,  x+8)  -- horizontal bands
vector(y+14, x+1, y+14, x+8)
vector(y+2,  x+3, y+13, x+3)  -- vertical bands
vector(y+2,  x+6, y+13, x+6)
end
Drawing all this stuff increases the vector count to 232.  That's pretty good going.
We still have sprites for Jumpman, Pauline, Fireballs, Donkey Kong, hammer smashing, oilcan flames and barrels to deal with.  We'll also need to make a vector font to show the scores, level, bonus timer, bonus points and other messages.
I'll look at adding vector sprites in the next part.  The vector sprites will have to be cleverly linked to the game logic so they behave similarly to the pixel sprites.
Here are the functions responsible for varying the intensity and wobble of the vectors.
function intensity()
-- we can vary the brightness of the vectors
return ({0xbbffffff, 0xddffffff, 0xffffffff})[math.random(3)]
end
function wobble()
-- random change of the vector offset
return math.random(-40, 60) / 100 -- random change of the vector offset
end
Here's a video showing progress with the girders stage.  I've hacked out the original background graphics for now so they don't interfere with our new vector graphics.
This is all monochrome for now,  but maybe later we can think about adding splashes of colour.
My experimental code is on github at https://github.com/10yard/vectorkong
Jon
« Last Edit: June 02, 2022, 08:11:18 am by 10yard »
Check out my Donkey Kong Arcade Frontend at https://github.com/10yard/dkafe#readme
  • Last login:Yesterday at 12:46:21 pm
Re: Vectorising an arcade game
« Reply #1 on: April 15, 2022, 01:24:52 pm »
You are quite mad. I like it.  :applaud:
bobbyb13
  • Last login:Yesterday at 10:11:34 pm
« Reply #2 on: April 15, 2022, 01:30:47 pm »
This is rad.
I remember hearing commentary from a developer of games back in the day in regard to limit of how many lines they could draw without blowing up the chassis.
So I suppose you don't have that limitation!
Will the software eventually max out when you hit a specific line number?
It occurred to me that in a standard game of DK there is far more going on than in even an upper level of Tempest.
Awesome project.  Look forward to seeing your progress!
meyer980
  • Last login:January 26, 2026, 08:20:18 pm
  • Building fun things for fun
    • Sergio Stuff
« Reply #3 on: April 15, 2022, 02:01:28 pm »
Talk about a new challenge! Very interesting
10yard
    • DKAFE Frontend
« Reply #4 on: April 15, 2022, 06:43:32 pm »
Yes, being mad keeps me sane.  Thanks!
10yard
    • DKAFE Frontend
« Reply #5 on: April 15, 2022, 07:01:42 pm »
This is rad.
Fortunately,  my limitations are all with software!  Yes there will be a maximum amount of computation and drawing that can be done per frame before emulation is compromised but this will vary based on the machine, resolution and MAME version.   I’ll keep a check on things as I go.  I’m reminded of the book “Racing the Beam” about Atari VCS programmers generating graphics literally in real time, drawing on the screen as the TV’s electron gun was passing over the tube.
Yes theres a lot going on in DK.  I’m not even thinking about the other stages yet.
Thanks man!
10yard
    • DKAFE Frontend
« Reply #6 on: April 15, 2022, 07:06:39 pm »
Hey,  thanks!  Loving your DK and Felix projects.
meyer980
    • Sergio Stuff
« Reply #7 on: April 15, 2022, 08:12:27 pm »
Racing the beam is fantastic, I enjoyed it a lot.
With your skills/interest, you should consider writing an original game. Something I've always wanted to do (but don't have the knowledge) is create a new Nintendo Vs. game that could run on actual hardware- similar to this project: http://vs.frombelowgame.com/
The boards are well documented and with swappable ROMs, it's theoretically an easy-ish system to create a new game for. I would love it if someone created a new two-sided game lol
I did in my own way, making a game called Vs. Moon Melee but I only know how to make games for modern hardware.
10yard
    • DKAFE Frontend
« Reply #8 on: April 16, 2022, 05:57:28 pm »
One of my long term goals is to develop a game for arcade hardware.  I really don't know anything about the Vs system so i will have to take a look when I get chance.  Man,  there is so much to learn and do and just not enough time.
Your Vs Moon Melee looks great.
Xiaou2
  • Last login:Yesterday at 02:38:18 pm
  • NOM NOM NOM
« Reply #9 on: April 17, 2022, 09:57:56 pm »
Pretty cool stuff
 But just an FYI about Vector drawing, with real hardware:
 Due to how a vector monitor draws (like a "Plotter", OR CNC cutter),  and due to the limits on how much it can draw..
the programmers would probably highly Optimize how things were drawn.
 A vector, is drawn by a single electron beam... from one point to another.  When moving from one object
to another... the electron beam voltage is reduced so that there is no visible line between them.  BUT..
if you Crank a vector monitors voltage up... you can actually see that all of the picture is a Continuous line.
 Visible Lines:      A----B----C      D--E---------F
 Actual Drawing:  A----B----C-----D--E---------F
 As such... your Oil Barrel, would probably be drawn as a single line object.. instead of several boxes stacked
on top of each other.  This would also eliminate the issue that you are seeing.. where two edge lines do not
match up.
 Maybe something like this:
         eA--------B
          F--------G
          I--------H
          D--------C
 That said.. Im just guessing about the way they would have drawn it.  They may have
had to test a few different versions to see which were faster, and most optimal.
 Also, Vectors can have different brightness levels.  Part of this is probably programmed..
but part of it may be due to them utilizing Time-Delays as well as drawing certain things
a few more times in the same area, to create much greater brightness effects.
 I believe you can turn up the values in mame, to see the entire vector path, including the
"Invisible" lines.  That should help in figuring out how the programmers drew them.
 As for the Vector Kong art.. Its cool, but a bit basic.  Id suggest adding Zig-Zags in
the Girders, to give it that same familiar raster look.  (At very least, close the ends of
each Girder)
 Id Personally LOVE to see an Updated version of Star Wars... where the Trench Run is a
drawn a bit more complex.  Instead of just having simple boxes to dodge... imagine
if the entire trench itself, was at different levels.. going up, down.. and side to side.
 And even better... would be a Stereoscopic version.  Red/Blue glasses could be used
to see the depth.  And or displaying it in stereo with some adapted shutter glasses, or VR glasses.
 I also had an idea for a Vector level, where one could fly on a Speeder-Bike.
The raster Jedi game was OK.. but It would be cool to see an all Vector version instead.
« Last Edit: April 17, 2022, 10:04:45 pm by Xiaou2 »
10yard
    • DKAFE Frontend
« Reply #10 on: April 19, 2022, 03:12:04 pm »
match up.
         eA--------B
          F--------G
          I--------H
          D--------C
Hey Xiaou2,  thank you for your detailed information and examples.
I've recently optimised the polyline draw function to allow continuous line drawing.  The function now recognises breaks in the line object allowing for a connecting line to be effectively skipped - similar to your description of the low intensity vectors.  A bonus of this optimisation is that line objects can be easily stored into a library for easy programmatic retrieval.
See the entries for oilcan, hammer and barrel below.  The numbers are a list of X,Y endpoints in pairs.  "BR" represents a break in the continuous line.  When BR,BR is encountered the connecting line is hidden.  Now there are NO overlaps in the line drawing at all.
vector_lib["oilcan"] = {1,1,15,1,BR,BR,1,15,15,15,BR,BR,5,1,5,15,BR,BR,12,1,12,15,BR,BR,7,4,10,4,10,7,7,7,7,4,BR,BR,7,9,10,9,BR,BR,7,13,7,11,10,11,BR,BR,15,0,16,0,16,16,15,16,15,0,BR,BR,1,0,0,0,0,16,1,16,1,0}
vector_lib["hammer"] = {5,0,7,0,8,1,8,8,7,9,5,9,4,8,4,1,5,0,BR,BR,4,4,0,4,0,5,4,5,BR,BR,8,4,9,4,9,5,8,5}
vector_lib["barrel"] = {3,0,12,0,15,2,15,7,12,9,3,9,0,7,0,7,0,2,3,0,BR,BR,1,2,1,7,BR,BR,14,2,14,7,BR,BR,2,3,13,3,BR,BR,2,6,13,6}
I have a function to vary the line intensity.  At the moment,  the intensity is randomised.  I will likely adjust the function later to vary brightness of the background and emphasis sprites.  I may add splashes of colour.
each Girder)
I intentionally made the girders simple to keep the vector count down to a minimum.  You made me rethink things,  the zig-zag girders are very familiar to DK.  I did some tests with added zig-zags.  I also closed the girder ends as you recommended.
1) Full zig-zags = 579 vectors for background
2) Half zig-zags = 415 vectors for background
3) Big zig-zags - 415 vectors for background
4) Spaced zig-zags = 415 vectors for background
I really like 4.
In other news,  I've made really good progress with character/font sprites and will have an update out very soon.
« Last Edit: May 04, 2022, 03:50:44 am by 10yard »
10yard
    • DKAFE Frontend
« Reply #11 on: April 19, 2022, 03:25:38 pm »
Here's another variation of the girder zig-zags.  The zig-zags have a slightly increased height.
I'm also showing a sneak preview here of the work that i've done with vectorising the DK character/fonts.  This explains why the vector count is increased.  For comparison with above this would be 415 vectors for the background.
5) spaced zig-zags variation
I'd be interested to know what is your favourite option 1-5?
« Last Edit: April 19, 2022, 03:32:32 pm by 10yard »
10yard
    • DKAFE Frontend
Re: Vectorising an arcade game: Part 2
« Reply #12 on: April 21, 2022, 10:00:02 am »
In this part 2,  I'm going to be vectorising the character/fonts that are used by the game.
The Donkey Kong rom includes 2 graphics banks.  Bank 1 includes 256 characters which are sized at 8 x 8 pixels.  Bank 2 includes 128 sprites which are sized at 16 x 16 pixels.
We'll be working with bank 1.  The characters in this bank comprise mostly of numbers, letters and punctuation.
The Donkey Kong game outputs characters from bank 1 to the screen by utilising video RAM.  The video RAM is located in RAM memory from address 7440 to 77ff.
We can see video RAM in the MAME debugger.
mame dkong -debug
In the debugger,  open a new memory window,  increase the byte width from 16 to 32 bytes (by pressing Ctrl+P 16 times), enter 7440 into the box and select "Run" from the menu.
*The 32 bytes correspond to the height of the screen in DK i.e. 32 characters x 8 pixels = 256 pixel high.  Address 7440 relates to the top-right corner of the screen.  The video ram appears rotated when viewed in the debugger.
I've annotated the debugger to show how we can determine characters that are output to the screen.  The character chart below can be used to translate each of the hexadecimal values to a specific character graphic.  For example,  the wording for "HIGH SCORE" is made up from hex values: 18,19,17,18,10,23,13,1F,22,15.  In the chart,  "H" is found at 10 + 8 = 18.  "I" is found at 10 + 9 = 19  etc.
For reference,  the video ram is showing the content of the name registration screen.  It's perfect for our test because it contains the full alphabet of characters.
I fleshed out a function to iterate through all of the 896 characters (32 x 28 characters) in video ram. We're getting ahead of ourselves so we'll come back to this function later when we've figured out how to draw characters from bank 1 as vectors.
function draw_vector_characters()
-- Output vector characters based on contents of video ram ($7440-77ff)
local _addr = 0x7440
for _x=223, 0, -8 do  -- 32 characters
for _y=255, 0, -8 do  -- 28 characters
-- <<<< FIGURE OUT HOW TO DRAW VECTOR CHARACTER AT y, x POSITION >>>>
_addr = _addr + 1
end
end
end
Ok,  so now we can look into vectorising the pixel characters from bank 1.
We may as well start with zero,  the first character in the bank.   The image below shows how I can draw a vector outline by joining all of the points with 8 lines. The points are relative to 0,0 at the bottom-left corner.
So our y, x points forming the zero character are: 0,2 - 0,4 - 2,6 - 4,6 - 6,4 - 6,2 - 4,0 - 2,0 - 0,2
This can be plotted to the screen using our existing polyline function as follows.
polyline{0,2,0,4,2,6,4,6,6,4,6,2,4,0,2,0,0,2}
I took on the tedious task of vectorising all of the characters we're going to need and stored the results into a vector library.  This will give us convenient access in our LUA program.
The ID in the vector library e.g. [0x00] matches with the hexadecimal value in our character lookup table above.
vector_lib[0x00] = {0,2,0,4,2,6,4,6,6,4,6,2,4,0,2,0,0,2} -- 0
vector_lib[0x01] = {0,0,0,6,BR,BR,0,3,6,3,5, 1} -- 1
vector_lib[0x02] = {0,6,0,0,5,6,6,3,5,0} -- 2
vector_lib[0x03] = {1,0,0,1,0,5,1,6,2,6,3,5,3,2,6,6,6,1} -- 3
vector_lib[0x04] = {0,5,6,5,2,0,2,7} -- 4
vector_lib[0x05] = {1,0,0,1,0,5,2,6,4,5,4,0,6,0,6,5} -- 5
vector_lib[0x06] = {3,0,1,0,0,1,0,5,1,6,2,6,3,5,3,0,6,2,6,5} -- 6
vector_lib[0x07] = {6,0,6,6,0,2} -- 7
vector_lib[0x08] = {2,0,0,1,0,5,2,6,5,0,6,1,6,4,5,5,2,0} -- 8
vector_lib[0x09] = {0,1,0,4,2,6,5,6,6,5,6,1,5,0,4,0,3,1,3,6} -- 9
vector_lib[0x11] = {0,0,4,0,6,3,4,6,0,6,BR,BR,2,6,2,0}  -- A
vector_lib[0x12] = {0,0,6,0,6,5,5,6,4,6,3,5,2,6,1,6,0,5,0,0,BR,BR,3,0,3,4}  -- B
vector_lib[0x13] = {1,6,0,5,0,2,2,0,4,0,6,2,6,5,5,6} -- C
vector_lib[0x14] = {0,0,6,0,6,4,4,6,2,6,0,4,0,0} -- D
vector_lib[0x15] = {0,5,0,0,6,0,6,5,BR,BR,3,0,3,4} -- E
vector_lib[0x16] = {0,0,6,0,6,6,BR,BR,3,0,3,5} -- F
vector_lib[0x17] = {3,4,3,6,0,6,0,2,2,0,4,0,6,2,6,6} -- G
vector_lib[0x18] = {0,0,6,0,BR,BR,3,0,3,6,BR,BR,0,6,6,6} -- H
vector_lib[0x19] = {0,0,0,6,BR,BR,0,3,6,3,BR,BR,6,0,6,6} -- I
vector_lib[0x1a] = {1,0,0,1,0,5,1,6,6,6} -- J
vector_lib[0x1b] = {0,0,6,0,BR,BR,3,0,0,6,BR,BR,3,0,6,6} -- K
vector_lib[0x1c] = {6,0,0,0,0,5} -- L
vector_lib[0x1d] = {0,0,6,0,2,3,6,6,0,6}  -- M
vector_lib[0x1e] = {0,0,6,0,0,6,6,6} -- N
vector_lib[0x1f] = {1,0,5,0,6,1,6,5,5,6,1,6,0,5,0,1,1,0} -- O
vector_lib[0x20] = {0,0,6,0,6,5,5,6,3,6,2,5,2,0} -- P
vector_lib[0x21] = {1,0,5,0,6,1,6,5,5,6,2,6,0,4,0,1,1,0,BR,BR,0,6,2,3} -- Q
vector_lib[0x22] = {0,0,6,0,6,5,5,6,4,6,2,3,2,0,2,3,0,6} -- R
vector_lib[0x23] = {1,0,0,1,0,5,1,6,2,6,4,0,5,0,6,1,6,4,5,5} -- S
vector_lib[0x24] = {6,0,6,6,BR,BR,6,3,0,3} -- T
vector_lib[0x25] = {6,0,1,0,0,1,0,5,1,6,6,6} -- U
vector_lib[0x26] = {6,0,3,0,0,3,3,6,6,6} -- V
vector_lib[0x27] = {6,0,2,0,0,1,4,3,0,5,2,6,6,6}  -- W
vector_lib[0x28] = {0,0,6,6,3,3,6,0,0,6} -- X
vector_lib[0x29] = {6,0,3,3,6,6,BR,BR,3,3,0,3} -- Y
vector_lib[0x2a] = {6,0,6,6,0,0,0,6} -- Z
vector_lib[0x2b] = {0,0,1,0,1,1,0,1,0,0}  -- dot
vector_lib[0x2c] = {3,0,3,5} -- dash
vector_lib[0x2d] = {5,0,5,6} -- underscore
vector_lib[0x2e] = {4,3,4,3,BR,BR,2,3,2,3} -- colon
vector_lib[0x2f] = {5,0,5,6} -- Alt underscore
vector_lib[0x34] = {2,0,2,5,BR,BR,4,0,4,5} -- equals
vector_lib[0x35] = {3,0,3,5} -- dash
vector_lib[0x44] = {0,5,4,5,4,7,2,7,0,8,BR,BR,2,5,2,7,BR,BR,4,10,1,10,0,11,0,12,1,13,4,13,BR,BR,0,15,4,15,4,17,2,17,2,18,0,18,0,15,BR,BR,2,15,2,17,BR,BR,0,23,0,21,4,21,4,23,BR,BR,2,21,2,22,BR,BR,0,25,4,25,0,28,4,28,BR,BR,0,30,4,30,4,32,3,33,1,33,0,32,0,30} -- rub / end
vector_lib[0x49] = {0,4,2,2,5,2,7,4,7,8,5,10,2,10,0,8,0,4,BR,BR,2,7,2,5,5,5,5,7} -- copyright
vector_lib[0x6c] = {2,0,2,4,3,5,4,4,5,5,6,4,6,0,2,0,BR,BR,4,4,4,0,BR,BR,3,7,2,8,2,11,3,12,5,12,6,11,6,8,5,7,3,7,BR,BR,2,14,6,14,2,19,6,19,BR,BR,6,21,3,21,2,22,2,25,3,26,6,26,BR,BR,2,28,2,31,4,31,4,28,5,28,6,29,6,31, B,BR,6,-2,6,-5,-12,-5,-12,36,6,36,6,33,BR,BR,0,-3,-10,-3,-10,34,0,34,0,-3} -- bonus
vector_lib[0x9f] = {2,0,0,2,0,13,2,15,5,15,7,13,7,2,5,0,2,0,BR,BR,5,3,5,7,BR,BR,5,5,2,5,BR,BR,2,8,5,8,4,10,5,12,2,12} -- TM
vector_lib[0xb0] = {0,0,0,8,BR,BR,1,0,1,8,BR,BR,7,0,7,8,BR,BR,6,0,6,8} -- Block
vector_lib[0xb1] = {0,0,7,0,7,7,0,7,0,0} -- Box
vector_lib[0xb7] = {0,1,1,1,1,2,6,2,6,1,7,1,7,3,6,3,6,5,7,5,7,7,6,7,6,6,1,6,1,7,0,7,0,1} -- Rivet
vector_lib[0xdd] = {0,0,7,0,BR,BR,4,0,4,4,BR,BR,1,4,7,4,BR,BR,2,9,1,6,7,6,7,9,BR,BR,5,6,5,9,BR,BR,7,11,2,11,3,14,BR,BR,3,16,7,16,7,18,6,19,5,18,5,16,BR,BR,7,22,5,21,BR,BR,3,21,3,21} -- Help (big H)
vector_lib[0xed] = {7,0,5,0,BR,BR,6,0,6,4,BR,BR,7,4,4,4,BR,BR,7,9,7,6,4,6,3,9,BR,BR,5,6,5,9,BR,BR,7,11,3,11,2,14,BR,BR,1,16,7,16,7,19,3,19,3,16,BR,BR,7,22,2,21,BR,BR,0,20,0,21} -- Help (little H)
vector_lib[0xfb] = {5,1,6,2,6,5,5,6,4,6,2,3,BR,BR,0,3,0,3} -- question mark
vector_lib[0xfd] = {-1,0,7,0} -- vertical line
vector_lib[0xfe] = {0,0,7,0,7,7,0,7,0,0} -- cross
vector_lib[0xff] = {5,2,7,2,7,4,5,4,5,2,BR,BR,5,3,2,3,0,1,BR,BR,2,3,0,5,BR,BR,4,0,3,1,3,5,4,6} -- jumpman / stick man
Some entries in the table are more complex than others e.g. [0x6c] is the bonus box,  it is comprised of multiple characters as it is convenient for us to link them together.
We can now complete the work on our vector drawing function we fleshed out earlier and visualise the results in MAME.
-- Output vector characters based on contents of video ram ($7400-77ff)
polyline(vector_lib[mem:read_u8(_addr)], _y - 6, _x - 6)
_addr = _addr + 1
end
end
end
Here's what the name registration screen looks like now:
and the DK title screen:
and here's a gameplay video showing our progress.
Note that I've hacked the game for now so that we will only play on the barrel stage.  This function gets called at the end of the stage.
local STAGE, LEVEL =  0x6227, 0x6229
function debug_stay_on_girders()
mem:write_u8(STAGE, 1);
mem:write_u8(LEVEL, mem:read_u8(LEVEL) + 1)
end
« Last Edit: May 04, 2022, 03:56:43 am by 10yard »
zeorangr
  • Last login:February 11, 2026, 11:22:06 pm
    • forum.arcadecontrols.com/index.php/topic,165836.0.html
Re: Vectorising an arcade game: Updated
« Reply #13 on: April 21, 2022, 10:32:56 am »
This is really cool!
-z-
Gilrock
« Reply #14 on: April 21, 2022, 11:10:41 am »
Cool work.  Not sure I could stare at that "wobble" very long.  Maybe tone down how many vectors wobble per frame.
10yard
    • DKAFE Frontend
« Reply #15 on: April 21, 2022, 11:15:22 am »
Yes,  you're probably right Gilrock.   I will tone down or turn off the wobble for the background.  Then I can sparingly use wobble or colourisation to emphasise the foreground sprites when they're done.   :cheers:
EDIT - I've updated the gameplay video and removed the wobble.
« Last Edit: April 21, 2022, 12:16:47 pm by 10yard »
nitrogen_widget
« Reply #16 on: April 21, 2022, 07:45:02 pm »
will dk, mario, barrels, ect get color vectorized?
« Reply #17 on: April 21, 2022, 09:28:04 pm »
Crank up the wobble when Donkey Kong moves.  It’ll be like glasses of water do when I walk around the house.
10yard
    • DKAFE Frontend
« Reply #18 on: April 21, 2022, 11:33:46 pm »
Yes,  I think they’ll have to be coloured to stand out from the background.
« Last Edit: April 21, 2022, 11:50:53 pm by 10yard »
10yard
    • DKAFE Frontend
« Reply #19 on: April 21, 2022, 11:38:32 pm »
Love it.  I can make that work.  What a great idea.  :cheers:
bobbyb13
« Reply #20 on: April 22, 2022, 12:27:59 am »
Cooler by the minute!
I'm still awestruck at this kind of work.
Absolutely brilliant.
10yard
    • DKAFE Frontend
« Reply #21 on: April 22, 2022, 05:25:01 pm »
Thank you!
10yard
    • DKAFE Frontend
Re: Vectorising an arcade game: Updated with Part 3a
« Reply #22 on: May 03, 2022, 03:47:25 pm »
In this part 3a,  I'm going to be adding vector sprites for Oilcan Flames, Fireballs, Barrels, Pauline and Paulines Love Heart.  I've also introduced colour.
First thing to report is my graphics optimisation resulting in a significant increase to the vectors that can be drawn per frame.
I was able to triple the limit - to 3000 vectors per frame*.  We're not going to get anywhere near those numbers.
* Tested with MAME version 0.243 running fullscreen opengl video.
I was able to programmatically clear the roms sprite banks during startup.  There is an overhead for MAME to draw stuff and we won't need the games original pixel graphics at all.  My previous hack was just to hide them in the background.  This is a much better solution.
function clear_graphic_banks()
-- clear the contents of the DK graphics banks 1 and 2
local _bank1, _bank2 = bnk.regions[":gfx1"], bnk.regions[":gfx2"]
if _bank1 and _bank2 then
for _addr=0, 0xfff do _bank1:write_u8(_addr, 0) end  -- clear bank 1
for _addr=0, 0x1fff do _bank2:write_u8(_addr, 0) end  -- clear bank 2
end
end
So back to the main focus of this update.  I made progress with drawing and animating sprites.
I made vectors versions of the needed sprites and added them to my program's vector library.  I used a paint program to draw lines and to experiment with how things would look e.g.
I added flames to the oilcan first as I thought that would be fairly simple.  The flames ignite after the first blue barrel strikes the oilcan.  I check the flame (memory location 0x6a29) is active (value is between 0x40 and 0x43) and then draw flames as vectors in yellow and red.  The red flame extends upwards in a simple random animation.
function draw_oilcan_and_flames(y, x)
draw_object("oilcan",  y, x)
local _sprite = read(0x6a29)
if _sprite >= 0x40 and _sprite <= 0x43 then  -- oilcan is on fire
draw_object("flames", y+16, x, YEL)  -- base of flames
draw_object("flames", y+16+math.random(0,3), x, RED)  -- flames extend upwards
end
end
Fireballs were taxing.  There are 6 fireball slots in RAM.  Each fireball has 32 bytes of data including status (active/inactive), current x/y position, colour and direction of movement.  I check each fireball slot every frame looking for active fireballs,  I draw active fireballs in 3 parts:  The body in yellow,  the flames extending upwards in red and the eyes in red.  The flames were given a simple animation similar to the oilcan flame effect.  If the fireball changes direction then I flip the fireball vectors so they are mirrored when drawn.
function draw_fireballs()
local _y, _x
for _i, _addr in ipairs(FIREBALLS) do
if read(_addr, 1) then  -- fireball is active
_y, _x = 247 - read(_addr+5), read(_addr+3) - 22
if read(_addr+0xd, 1) then
vector_flip = 13  -- fireball is moving right so flip the vectors
end
draw_object("fire-1", _y, _x, YEL) -- draw body
draw_object("fire-2", _y+math.random(0,3), _x, RED)  -- draw flames extending upwards
draw_object("fire-3", _y+1, _x, RED)  -- draw eyes
vector_flip = 0
end
end
end
Here's the Oilcan with flames throwing out a fireball.
Barrels were even more taxing than fireballs.  There are 8 barrel slots in RAM.  Similar to fireballs,  each barrel has 32 bytes of corresponding data.  The data comprises of status (inactive/being deployed/rolling), color indicator (normal or blue), crazy barrel indicator, movement direction, current x/y position and a bunch of other stuff.
If the barrel is crazy/wild or going down a ladder then I draw a longer sideways barrel.  These can be blue or brown.
otherwise I draw a circular rolling barrel.  These can also be blue or brown.
Here's my function for handling the barrels and their rolling animation.
function draw_barrels()
local _y, _x, _type, _state
for _i, _addr in ipairs(BARRELS) do
if read(_addr) > 0 and read(0x6200, 1) and read(_addr+3) > 0 then  -- barrel active and Jumpman alive
_y, _x = 251 - read(_addr+5), read(_addr+3) - 20
_type = read(_addr+0x15) + 1  -- type of barrel: 1 is normal, 2 is blue/skull
if read(_addr+1, 1) or bits(read(_addr+2))[1] == 1 then  -- barrel is crazy or going down a ladder
_state = read(_addr+0xf)
draw_object("down", _y, _x-2, ({BRN, CYN})[_type])
draw_object("down-"..tostring(_state % 2 + 1), _y, _x - 2, ({LBR, BLU})[_type])
else  -- barrel is rolling
_state = barrel_state[_addr] or 0
if scr:frame_number() % 10 == 0 then
if read(_addr+2, 2) then _state = _state - 1 else _state = _state+1 end  -- roll left or right?
barrel_state[_addr] = _state
end
draw_object("roll", _y, _x, ({BRN, CYN})[_type])
draw_object(({"roll-", "skull-"})[_type]..tostring(_state % 4 + 1), _y, _x,({LBR, BLU})[_type])
end
end
end
end
I made a simple vector representation of Pauline and her love heart/broken heart.
This function check for Paulines animation state.  The original DK uses several sprites for Pauline as she rocks back and forth.  I made her Jump up instead to keep the effect simple.
function draw_pauline()
local _y, _x = 235 - read(0x6903), 90
if read(0x6905) ~= 17 and read(0x6a20, 0) then _y = _y + 3 end  -- Pauline jumps when heart not showing
draw_object("paul-1", _y, _x, MAG)
draw_object("paul-2", _y, _x, PNK)
end
This function reads the status of the love heart (full or broken) and position prior to drawing.
function draw_loveheart()
_y, _x = 250 - read(0x6a23), read(0x6a20) - 23
if _x > 0 then draw_object(read(0x6a21) + 0xf00, _y, _x, MAG) end
end
Lastly,  I made bonus points appear when jumping or smashing barrels.  I adjusted the y position so bonus points don’t overlap with the girders.
function draw_points()
-- draw 100, 300, 500 or 800 when points awarded
if read(0x6a30) > 0 then
_y, _x = 254 - read(0x6a33), read(0x6a30) - 22
draw_object(read(0x6a31) + 0xf00, _y+3, _x, YEL)  -- move points up a little so they don't overlap as much
end
end
The hammer smashing animation still needs to be done,  along with other sprites for Jumpman and Donkey Kong.  They should be in the next part.
Here's a gameplay video showing my progress so far (without hammer smashing).   I've used a simple box to represent Jumpman's position on screen.  Hey,  it's almost playable like this.
« Last Edit: May 10, 2022, 07:18:30 am by 10yard »
nitrogen_widget
Re: Vectorising an arcade game: Updated with part 3
« Reply #23 on: May 05, 2022, 06:54:36 pm »
this is looking really cool.
10yard
    • DKAFE Frontend
« Reply #24 on: May 06, 2022, 07:22:56 am »
Thanks!  It's all coming together nicely.
This project is more work than I was expecting but that's typical.  I'm enjoying the journey.
Working on Kong at the mo.  It's hard to get the familiarity without overdoing the vectors.  He's looking grumpier  :lol.
« Last Edit: May 07, 2022, 03:13:08 pm by 10yard »
Locke141
  • Never grow up.
« Reply #25 on: May 07, 2022, 06:09:38 pm »
I'm impressed.
10yard
    • DKAFE Frontend
Re: Vectorising an arcade game: Updated with part 3b
« Reply #26 on: May 10, 2022, 07:56:27 am »
In this part 3b,  I'll be adding vector sprites for Donkey Kong himself.  There's a lot of work to do for sprites so I figured I would break part 3 up into multiple sub-parts.
Ok,  our first thing to tackle is the Kong facing forwards graphic which is his default stance.  He appears like this on the "title screen",  the "how high can you get" screen and on the girders stage when he's not deploying barrels.
I used a paint program to help me draw out vectors on top of a template.  The template includes co-ordinates which will help me translate my work to a list of points we can draw in the game.  The graphic is mirrored along a center line so I need only draw vectors for one side and then use my existing mirror function to complete the work.  I'm using bright colours for now so they stand out.  These will be replaced with different shades of brown when added to the game.
The list of Kong's vectors is quite large.
31,20,31,17,27,13,25,13,25,15,28,15,29,16,30,18,30,19,29,20,BR,BR,25,20,25,18,24,18,24,20,BR,BR,21,15,22,16,22,20,BR,BR,26,18,27,18,27,19,26,19,26,18,BR,BR,6,20,6,16,2,12,BR,BR,2,4,4,4,5,3,7,3,11,7,13,7,13,4,16,1,19,1,23,6,24,8,24,10,BR,BR,7,15,8,14,10,14,BR,BR,19,6,17,10,16,13,BR,BR,10,13,11,10,BR,MBR,27,13,27,11,26,10,25,10,21,11,20,14,19,14,18,16,18,20,BR,BR,2,12,0,11,0,0,2,2,2,4,BR,BR,16,13,16,15,15,18,14,19,12,19,10,17,10,13,BR,BR,6,17,7,17,8,16,BR,BR,6,19,7,19,8,18,BR,BR,1,10,2,11,BR,BR,1,5,2,6,BR,BR,28,17,28,19,26,19,26,17,28,17,BR,LBR,26,18,27,18,27,19,26,19,26,18}
I used the same approach to draw vectors for Kong deploying barrels.  Kong grabs a barrel from the left side and releases a barrel to the right side.  The graphic is mirrored so I need only draw one side view.
In the paint tool,  I remove the template layer so I can visualise better how the vectors will look.
There's also the graphic of Kong holding a barrel about to be deployed.  I shuffled his chest up and to the left so it was not obscured by the barrel.  With vectors,  there isn't really a foregound/background, everything just overlaps and can confuse the look.
Here's the result when all 4 vector graphics are animated.  I'm really happy with how this is looking.
Finally,  there's a growling mouth to add.  Kong growls on the title screen and also at the end of each stage.  The growling vectors are overlaid onto a front facing Kong.
The title screen and how high screens can now be finished.
I added Kong's graphics to my LUA code.  This function places kong on screen at a given position.  The function queries the state of Kong to determine which of the 4 vectors graphics to display and whether we should make him growl.  The function deals with the mirroring when necessary.  When deploying barrels, I also had to overlay a barrel graphic (brown or blue) into Kong's hands.
function draw_kong(y, x, growl)
local _state = read(0x691d) -- state of kong - is he deploying a barrel?
local _data -- barrel data
if read(0x6382,0x80,0x81) then _data = {"skull-1",CYN,BLU} else _data = {"roll-1",LBR,MBR} end
if _state == 173 then
-- Kong releasing barrel to right
draw_object("dk-side", y, x+1, BRN)
draw_object("rolling", y, x+44, _data[2])
draw_object(_data[1], y, x+44, _data[3])
elseif _state == 45 then
-- Kong grabbing barrel from left (mirrored)
draw_object("dk-side", y, x-3, BRN, 42)
draw_object("rolling", y, x-15, _data[2])
draw_object(_data[1], y, x-15, _data[3])
elseif _state == 42 then
-- Kong front facing - holding a barrel
draw_object("dk-hold", y, x, BRN)  -- left side
draw_object("dk-hold", y, x+20, BRN, 20) -- mirrored right side
draw_object("down", y+2, x+12.4, _data[2])
draw_object("down-1", y+2, x+12.4, _data[3])
else
-- Default Kong front facing
draw_object("dk-front", y, x, BRN)  -- left side
draw_object("dk-front", y, x+20, BRN, 20) -- mirrored right side
if growl then
draw_object("dk-growl", y, x, MBR)  --left side
draw_object("dk-growl", y, x+20, MBR,20)  -- mirrored right side
end
end
end
Here's a video to show progress.
« Last Edit: May 11, 2022, 08:12:03 am by 10yard »
Gilrock
« Reply #27 on: May 10, 2022, 08:47:16 am »
Nice job on Kong.  I just bought an original Donkey Kong cab on Thursday so I'm re-learning how to play.
10yard
    • DKAFE Frontend
« Reply #28 on: May 10, 2022, 08:57:55 am »
Fantastic Gilrock!  I'd love to have an original cabinet one day.  I play a bit on MAME and targeting 500K,   current best is 309K.
What condition is your machine in?  Have you posted any pics?
Gilrock
« Reply #29 on: May 10, 2022, 09:13:01 am »
I posted a quick photo but it was in my Mame cabinet build thread as a side note.  The guy had stripped the paint and repainted it blue with new side art and a new marquee.  It looks almost brand new.  I'm going to replace the control panel overlay cause the acrylic has an 8" semi-circle crack that you really can't see in the photo.  Also he installed the wrong color buttons so I've ordered replacements from MikesArcade.
bobbyb13
« Reply #30 on: May 13, 2022, 02:25:00 am »
This project keeps getting cooler.
I still haven't even had time to implement the last one yet!!
I need to quit my adult life so that I can get on with some stuff that is actually important.
10yard
    • DKAFE Frontend
« Reply #31 on: May 13, 2022, 06:42:10 am »
Cool!  I'd love to see pics when you have it finished.  Is that all with original DK hardware?  and all running well?
Gilrock
« Reply #32 on: May 13, 2022, 01:09:07 pm »
Yeah I should create a separate thread for the DK cab.  All the boards are original except the CRT.  The original had a Sanyo and this has a K4900 with ani Berger from ArcadeShop.
MacGyver
  • Last login:December 18, 2023, 12:49:00 am
    • Project Build
« Reply #33 on: May 14, 2022, 10:01:02 pm »
I love it!
10yard
    • DKAFE Frontend
« Reply #34 on: May 18, 2022, 07:28:24 am »
I love it!
Cheers guys!  I needed that motivation to kick on with the project.  The Jumpman sprites are going to be the most difficult to get right,  and there's 18 variations of the fella!
That's one down.  I may tweak colours.  That blue is quite dark against a black background.
10yard
    • DKAFE Frontend
Re: Vectorising an arcade game: Updated with part 3c
« Reply #35 on: May 25, 2022, 01:15:23 pm »
In this part 3c,  I'll be working on the sprites for Jumpman a.k.a. Mario.  There's lots of drawing to be done.  By the end of this part we should have a fully playable barrels stage.
There are 18 variations of Jumpman:
3 x walking sprites
2 x jumping sprites
4 x ladder climbing sprites
6 x hammering sprites
3 x dying sprites
All these sprites are stored in graphic bank 2 of the Donkey Kong ROM at the offset position shown below e.g. jumping sprites are numbered 14 to 15.
As was done for Kong graphics (in part 3b),  I used a paint program to help me draw out the vectors for all of the Jumpman sprites.
Walking:
Jumping:
Ladder Climbing:
Hammering:
Dying:
I added all 18 of my drawings to the vector library in my program.
_lib["jm-0"] = {6,6,6,7,5,7,5,6,6,6,BR,BR,8,6,7,5,BR,BR,2,5,1,5,1,4,0,4,0,7,2,7,2,5,BR,BR,2,10,1,10,1,9,0,9,0,12,2,12,2,10,BR,BR,10,3,11,3,11,5,10,5,10,3,BR,BR,11,3,10,5,BR,BR,10,3,11,5,BR,BR,14,8,13,9,11,8,11,9,12,10,12,11,10,11,10,13,14,11,BR,BR,8,10,8,11,7,12,5,12,3,10,BR,BR,7,9,6,10,5,9,BR,RED,14,3,14,11,16,10,16,8,14,5,BR,BR,6,9,7,8,7,5,5,4,3,4,2,5,BR,BR,2,7,3,8,3,9,2,10,BR,BR,4,11,2,12,BR,GRY,14,6,13,5,12,3,11,2,11,3,10,4,9,4,8,6,BR,BR,8,10,10,11,BR,BR,5,9,4,8,3,9,3,10,BR,BR,13,6,13,7,12,7,12,6,13,6}
_lib["jm-1"] = {10,3,11,3,11,5,10,5,10,3,BR,BR,11,3,10,5,BR,BR,10,3,11,5,BR,BR,14,8,13,9,11,8,11,9,12,10,12,11,10,11,10,13,14,11,BR,BR,8,2,8,6,BR,BR,6,3,6,5,BR,BR,8,10,8,12,BR,BR,6,11,6,12,5,14,BR,BR,6,7,6,8,5,8,5,7,6,7,BR,BR,5,2,2,2,2,4,4,4,4,3,5,3,5,2,BR,BR,3,13,2,14,0,13,0,12,1,12,2,11,3,13,BR,RED,14,3,14,11,16,10,16,8,14,5,BR,BR,4,4,7,6,7,9,6,11,3,13,BR,BR,2,4,3,7,3,8,2,11,BR,GRY,14,6,13,5,12,3,11,2,11,3,10,4,9,4,8,6,BR,BR,8,10,10,11,BR,BR,13,6,13,7,12,7,12,6,13,6,BR,BR,8,2,8,1,7,1,6,2,6,3,BR,BR,7,14,7,15,5,15,5,14}
_lib["jm-2"] = {9,2,10,2,10,4,9,4,9,2,BR,BR,10,2,9,4,BR,BR,9,2,10,4,BR,BR,13,7,12,8,10,7,10,8,11,9,11,10,9,10,9,12,13,10,BR,BR,6,4,7,9,7,11,6,12,5,11,4,4,BR,BR,2,6,2,8,0,8,0,5,1,5,1,6,2,6,BR,BR,4,13,4,15,1,15,1,14,2,14,2,13,4,13,BR,RED,13,2,13,10,15,9,15,7,13,4,BR,BR,4,4,2,6,BR,BR,2,8,3,8,3,9,2,13,BR,BR,6,12,4,13,BR,GRY,13,5,12,4,11,2,10,1,10,2,9,3,8,3,7,5,BR,BR,7,9,9,10,BR,BR,12,5,12,6,11,6,11,5,12,5,BR,BR,6,4,6,2,5,2,4,4}
_lib["jm-3"] = {14,2,11,1,8,3,7,3,BR,BR,14,4,11,3,9,5,BR,BR,9,10,10,12,10,13,9,14,7,12,BR,BR,4,3,4,6,3,6,3,2,4,3,BR,BR,2,7,2,10,1,11,1,7,2,7,BR,BR,14,5,13,4,10,4,9,6,9,9,10,11,13,11,14,10,BR,RED,15,5,15,10,14,10,13,9,13,6,14,5,15,5,BR,BR,4,3,5,2,6,2,7,3,8,5,9,5,9,6,7,6,6,7,6,8,7,9,9,9,9,10,8,10,7,12,4,12,2,10,BR,GRY,14,2,15,3,15,4,14,4}
_lib["jm-4"] = {15,6,13,6,14,5,12,2,11,1,10,1,10,2,11,4,BR,BR,15,11,13,11,14,12,13,14,10,14,BR,BR,6,4,6,7,5,7,5,3,6,4,BR,BR,3,7,3,10,2,11,2,7,3,7,BR,RED,15,6,15,11,14,10,14,7,15,6,BR,BR,6,4,8,2,9,2,11,4,12,6,13,6,13,7,12,7,11,8,11,9,12,10,13,10,13,11,12,11,11,13,10,14,7,14,3,10}
_lib["jm-5"] = {7,1,7,5,6,5,6,1,7,1,BR,BR,3,7,3,10,2,11,2,7,3,7,BR,BR,11,12,9,14,7,15,6,15,BR,RED,7,1,8,0,9,0,11,2,12,4,12,6,11,7,11,8,12,9,12,10,11,12,9,13,5,13,3,10,BR,BR,3,7,5,9,6,9,7,7,7,5,BR,GRY,6,13,5,14,5,15,6,15}
_lib["jm-6"] = {14,5,13,4,10,4,9,6,9,9,10,11,13,11,14,10,BR,BR,5,1,7,1,9,3,9,5,BR,BR,9,10,9,12,7,14,4,14,BR,BR,0,3,0,7,1,7,1,4,0,3,BR,BR,1,8,0,8,0,12,1,11,1,8,BR,RED,15,5,15,10,14,10,13,9,13,6,14,5,15,5,BR,BR,1,7,2,6,3,7,3,8,2,9,1,8,BR,BR,1,4,2,3,6,3,8,5,9,5,9,6,6,6,5,7,5,8,6,9,9,9,9,10,8,10,6,12,2,12,1,11,BR,GRY,5,1,4,1,4,2,5,3,BR,BR,5,12,4,13,4,14,5,14}
_lib["jm-8"] = {11,3,11,5,10,5,10,3,11,3,BR,BR,10,3,11,5,BR,BR,11,3,10,5,BR,BR,14,11,10,13,10,10,12,11,12,9,BR,BR,14,7,9,7,7,9,6,11,7,12,8,11,9,9,14,9,BR,BR,8,6,7,5,BR,RED,16,9,16,10,14,11,14,9,BR,BR,14,3,14,7,BR,BR,14,5,16,8,BR,GRY,14,7,16,8,16,9,14,9,BR,BR,13,6,13,7,12,7,12,6,13,6,BR,BR,14,6,13,5,12,3,11,2,BR,BR,10,4,9,4,8,6,BR,BR,10,10,9,10,BR,RED,7,9,7,5,5,4,3,4,2,5,BR,BR,7,12,2,12,BR,BR,2,7,3,8,3,9,2,10,BR,BLU,6,6,6,7,5,7,5,6,6,6,BR,BR,2,5,2,7,0,7,0,4,1,4,1,5,2,5,BR,BR,2,10,2,12,0,12,0,9,1,9,1,10,2,10}
_lib["jm-9"] = {11,3,11,5,10,5,10,3,11,3,BR,BR,11,3,10,5,BR,BR,10,3,11,5,BR,BR,14,8,13,9,11,8,11,9,12,10,12,11,10,11,10,13,14,11,BR,BR,8,2,8,10,7,11,6,10,6,2,BR,RED,14,3,14,11,16,10,16,8,14,5,BR,GRY,13,6,13,7,12,7,12,6,13,6,BR,BR,14,6,13,5,12,3,11,2,11,3,BR,BR,10,4,9,4,8,5,BR,BR,8,10,10,10,BR,BR,8,2,8,0,7,0,6,2,BR,RED,6,4,3,4,2,5,BR,BR,2,7,3,8,3,9,2,10,BR,BR,2,12,5,11,7,11,BR,BLU,6,6,5,6,5,7,6,7,BR,BR,2,5,2,7,0,7,0,4,1,4,1,5,2,5,BR,BR,2,10,2,12,0,12,0,9,1,9,1,10,2,10}
_lib["jm-10"] = {11,3,11,5,10,5,10,3,11,3,BR,BR,10,3,11,5,BR,BR,11,3,10,5,BR,BR,14,11,10,13,10,10,12,11,12,9,BR,BR,14,7,9,7,7,9,6,11,7,12,8,11,9,9,14,9,BR,BR,8,6,7,5,BR,RED,16,9,16,10,14,11,14,9,BR,BR,14,3,14,7,BR,BR,14,5,16,8,BR,GRY,14,7,16,8,16,9,14,9,BR,BR,13,6,13,7,12,7,12,6,13,6,BR,BR,14,6,13,5,12,3,11,2,BR,BR,10,4,9,4,8,6,BR,BR,10,10,9,10,BR,RED,7,9,7,5,4,4,BR,BR,2,4,3,7,3,8,2,11,BR,BR,7,12,5,11,3,13,BR,BLU,4,4,4,3,5,3,5,2,2,2,2,4,4,4,BR,BR,2,11,3,13,2,14,0,13,0,12,1,12,2,11,BR,BR,6,6,6,7,5,7,5,6,6,6}
_lib["jm-11"] = {11,3,11,5,10,5,10,3,11,3,BR,BR,11,3,10,5,BR,BR,10,3,11,5,BR,BR,14,8,13,9,11,8,11,9,12,10,12,11,10,11,10,13,14,11,BR,BR,8,2,8,10,7,11,6,10,6,2,BR,RED,14,3,14,11,16,10,16,8,14,5,BR,GRY,13,6,13,7,12,7,12,6,13,6,BR,BR,14,6,13,5,12,3,11,2,11,3,BR,BR,10,4,9,4,8,5,BR,BR,8,10,10,10,BR,BR,8,2,8,0,7,0,6,2,BR,RED,6,5,4,4,BR,BR,2,4,3,7,3,8,2,11,BR,BR,7,11,5,11,3,13,BR,BLU,6,6,5,6,5,7,6,7,BR,BR,5,2,5,3,4,3,4,4,2,4,2,2,5,2,BR,BR,2,11,3,13,2,14,0,13,0,12,1,12,2,11}
_lib["jm-12"] = {11,2,11,4,10,4,10,2,11,2,BR,BR,10,2,11,4,BR,BR,11,2,10,4,BR,BR,14,10,10,12,10,9,12,10,12,8,BR,BR,14,6,9,6,7,8,6,10,7,11,8,10,9,8,14,8,BR,BR,8,5,7,4,BR,RED,16,8,16,9,14,10,14,8,BR,BR,14,2,14,6,BR,BR,14,4,16,7,BR,GRY,14,6,16,7,16,8,14,8,BR,BR,13,5,13,6,12,6,12,5,13,5,BR,BR,14,5,13,4,12,2,11,1,BR,BR,10,3,9,3,8,6,BR,BR,10,9,9,9,BR,RED,7,8,7,4,4,4,2,6,BR,BR,2,8,3,8,3,9,2,13,BR,BR,7,11,6,11,4,13,BR,BLU,6,6,6,7,5,7,5,6,6,6,BR,BR,0,5,0,8,2,8,2,6,1,6,1,5,0,5,BR,BR,4,13,4,15,1,15,1,14,2,14,2,13,4,13}
_lib["jm-13"] = {11,2,11,4,10,4,10,2,11,2,BR,BR,11,2,10,4,BR,BR,10,2,11,4,BR,BR,14,7,13,8,11,7,11,8,12,9,12,10,10,10,10,12,14,10,BR,BR,8,2,8,10,7,11,6,10,6,2,BR,RED,14,2,14,10,16,9,16,7,14,4,BR,GRY,13,5,13,6,12,6,12,5,13,5,BR,BR,14,5,13,4,12,2,11,1,11,2,BR,BR,10,3,9,3,8,4,BR,BR,8,10,10,10,BR,BR,8,2,8,0,7,0,6,2,BR,RED,6,4,4,4,2,6,BR,BR,2,8,3,8,3,9,2,13,BR,BR,4,13,6,11,7,11,BR,BLU,6,6,5,6,5,7,6,7,BR,BR,2,6,1,6,1,5,0,5,0,8,2,8,2,6,BR,BR,4,13,4,15,1,15,1,14,2,14,2,13,4,13}
_lib["jm-14"] = {9,3,10,3,10,5,9,5,9,3,BR,BR,10,3,9,5,BR,BR,9,3,10,5,BR,BR,13,8,12,9,10,8,10,9,11,10,11,11,9,11,9,13,13,11,BR,BR,1,1,4,1,4,2,3,2,3,3,1,3,1,1,BR,BR,3,12,5,13,3,15,2,15,3,14,2,13,3,12,BR,BR,7,3,7,6,BR,BR,5,2,5,5,BR,BR,7,10,8,13,BR,BR,5,11,6,14,BR,BR,5,7,5,8,4,8,4,7,5,7,BR,RED,13,3,13,11,15,10,15,8,13,5,BR,BR,3,3,6,6,6,9,5,11,3,11,3,12,BR,BR,1,3,2,7,2,8,0,10,0,11,2,13,BR,GRY,13,6,12,5,11,3,10,2,10,3,9,4,8,4,7,6,BR,BR,7,10,9,11,BR,BR,12,6,12,7,11,7,11,6,12,6,BR,BR,7,3,7,1,6,1,5,2,BR,BR,8,13,8,15,7,15,6,14}
_lib["jm-15"] = {10,4,11,4,11,6,10,6,10,4,BR,BR,11,4,10,6,BR,BR,10,4,11,6,BR,BR,14,9,13,10,11,9,11,10,12,11,12,12,10,12,10,14,14,12,BR,BR,9,11,9,13,7,16,6,16,BR,BR,6,12,7,13,6,14,BR,BR,7,3,8,4,9,6,9,8,BR,BR,5,4,6,5,7,7,7,8,BR,BR,2,1,3,2,2,3,3,4,1,5,0,3,2,1,BR,BR,2,6,3,7,2,8,3,9,1,10,0,8,2,6,BR,RED,14,4,14,12,16,11,16,9,14,6,BR,BR,3,4,4,5,6,6,7,8,7,10,6,12,3,13,1,10,BR,BR,1,5,2,6,BR,BR,3,9,4,10,BR,GRY,14,7,13,6,12,4,11,3,11,4,10,5,9,5,9,6,BR,BR,8,11,10,12,BR,BR,13,7,13,8,12,8,12,7,13,7,BR,BR,7,3,6,2,5,2,4,3,5,4,BR,BR,6,14,5,14,4,15,4,16,6,16,BR,BR,0,12,1,13,2,15,BR,BR,0,14,1,16}
_lib["jm-120"] = {14,4,10,2,10,4,BR,BR,12,4,14,6,BR,BR,14,11,10,13,10,11,BR,BR,12,11,14,9,BR,BR,11,4,11,6,10,7,10,8,11,9,11,11,10,10,10,9,9,8,9,7,10,6,10,5,11,4,BR,BR,9,5,8,4,9,2,BR,BR,9,10,8,11,9,13,BR,BR,6,4,6,3,8,1,BR,BR,6,11,6,12,8,14,BR,BR,6,5,6,6,5,6,5,5,6,5,BR,BR,6,9,6,10,5,10,5,9,6,9,BR,BR,4,3,2,5,1,4,2,1,3,1,4,3,BR,BR,2,10,4,12,3,13,3,14,2,14,1,11,2,10,BR,RED,14,3,14,12,BR,BR,14,4,15,5,15,10,14,11,BR,BR,4,3,6,4,7,5,8,5,8,6,7,6,6,7,6,8,7,9,8,9,8,10,7,10,6,11,4,12,BR,BR,2,5,3,7,3,8,2,10,BR,GRY,13,6,13,7,12,7,12,6,13,6,BR,BR,13,8,13,9,12,9,12,8,13,8,BR,BR,10,4,8,6,BR,BR,10,11,8,9,BR,BR,8,1,9,0,10,0,10,1,9,2,BR,BR,9,13,10,14,10,15,9,15,8,14,BR,BR,10,4,12,4,BR,BR,10,11,12,11}
_lib["jm-121"] = {10,2,11,1,14,2,14,3,13,3,12,4,10,2,BR,BR,5,2,3,4,2,3,1,3,1,2,4,1,5,2,BR,BR,10,5,10,6,9,6,9,5,10,5,BR,BR,6,5,6,6,5,6,5,5,6,5,BR,BR,11,6,12,6,14,8,BR,BR,10,9,11,8,13,9,BR,BR,4,6,3,6,1,8,BR,BR,5,9,4,8,2,9,BR,BR,11,10,13,10,11,14,BR,BR,4,10,2,10,4,14,BR,BR,11,12,9,14,BR,BR,6,14,4,12,BR,BR,11,11,9,11,8,10,7,10,6,11,4,11,5,10,6,10,7,9,8,9,9,10,10,10,11,11,BR,RED,12,14,3,14,BR,BR,11,14,10,15,5,15,4,14,BR,BR,12,4,11,6,10,7,10,8,9,8,9,7,8,6,7,6,6,7,6,8,5,8,5,7,4,6,3,4,BR,BR,10,2,8,3,7,3,5,2,BR,GRY,14,8,15,9,15,10,14,10,13,9,BR,BR,2,9,1,10,0,10,0,9,1,8,BR,BR,9,8,11,10,BR,BR,6,8,4,10,BR,BR,9,12,9,13,8,13,8,12,9,12,BR,BR,7,12,7,13,6,13,6,12,7,12}
_lib["jm-122"] = {10,2,12,3,11,7,10,7,10,6,9,5,10,2,BR,BR,6,4,6,5,5,5,5,4,6,4,BR,BR,2,2,2,5,4,7,3,8,2,8,0,6,0,0,1,0,2,2,BR,BR,8,10,8,11,5,11,5,10,8,10,BR,BR,8,10,5,11,BR,BR,8,11,5,10,BR,BR,0,14,0,9,1,8,1,11,2,11,1,13,2,14,BR,RED,0,14,8,14,BR,BR,0,14,1,16,3,16,6,14,BR,BR,14,8,15,9,15,13,14,14,12,14,11,13,11,9,12,8,14,8,BR,BR,10,2,9,1,7,1,6,0,4,0,3,1,2,1,BR,BR,9,5,8,4,7,4,6,7,5,8,BR,GRY,2,2,2,1,1,0,0,0,0,2,BR,BR,5,8,5,9,6,10,BR,BR,8,11,9,11,8,12,6,13,5,14,BR,BR,5,12,5,13,4,13,4,12,5,12}
I created a function to draw Jumpman's vectors to the screen.  The function queries the game memory to determine which of the 18 sprites to draw and whereabouts to draw it.
The sprite number is held in RAM at offset 0x694d.  This values matches one of the 18 Jumpman sprites we have in the vector library.  If the sprite number is greater than 128 then we subtract 128 and mirror the output to screen so that Jumpman faces the opposite direction.
e.g. for sprite 142,  we subtract 128 to get 14 which is the jumping left sprite.  We mirror it to get a jumping right sprite.
This function also deals with hammer smashing after Jumpman grabs the hammer.  The hammer follows Jumpman's position and the smashing movement is animated.
Items that are smashed by the hammer are cleared from the screen and a destruction animation is shown.
function draw_jumpman()
local _y, _x = 255 - read(0x6205), read(0x6203) - 15
local _sprite = read(0x694d)
local _sprite_mod = _sprite % 128
local _bright_blue = BLU + 0x1f1f0f
local _smash_offset = 9
local _grab
if _y < 255 then
if vector_lib["jm-"..tostring(_sprite_mod)] then
-- right facing sprites are mirrored.
-- < 128 are left facing sprites
-- (0,1,2) = walking, (3,4,5,6) = climbing, (8,9,10,11,12,13) = hammer smashing,
-- (14,15) = jumping, (120,121,122) = dead
_grab = read(0x6218, 1)
if _grab then -- grabbing hammer
if _sprite < 128 then _sprite = 10 else _sprite = 138 end  -- change default rite to a hammer grab
end
-- Display one of Jumpman's various sprites
draw_object("jm-"..tostring(_sprite), _y-7, _x-7, _bright_blue)
elseif _sprite == 248 then
draw_object("jm-"..tostring(_sprite-128), _y, _x-7, _bright_blue, nil, 8)  -- flip y
else
draw_object("jm-"..tostring(_sprite-128), _y-7, _x, _bright_blue, 8)  -- flip x
end
-- Add the hammer?
draw_object("hammer-up", _y+9, _x-3, MBR)
elseif _sprite_mod >= 8 and _sprite_mod <= 13 then  -- using hammer
if _sprite == 8 or _sprite == 10 then
elseif _sprite == 12 or _sprite == 140 then
draw_object("hammer-up", _y+9, _x-4, MBR)
elseif _sprite == 136 or _sprite == 138 then
draw_object("hammer-up", _y+9, _x-5, MBR)
elseif _sprite == 9 or _sprite == 11 or _sprite == 13 then
draw_object("hammer-down", _y-4, _x-16, MBR)
_smash_offset = -4
elseif _sprite == 137 or _sprite == 139 or _sprite == 141 then
draw_object("hammer-down", _y-4, _x+13, MBR, 4)
_smash_offset = -4
end
end
-- Add smashed item?
_sprite = read(0x6a2d)
if read(0x6a2c) > 0 and _sprite >= 0x60 and _sprite <= 0x63 then
draw_object(0xf00 + _sprite, _y+_smash_offset, read(0x6a2c) - 21, BLU)
end
end
end
end
This gif shows all of the vector sprites in action plus the hammer smashing.
The barrel stage is now fully playable.  Yay!
I've put out a release of the vectorkong plugin for test purposes.  This release will allow you to play the barrel stage only.
You can download the test release from my github at https://github.com/10yard/vectorkong/releases
Installing is simple.  You should extract the vectorkong folder from the ZIP and copy it over to your MAME plugins folder.
The Plugin is run by adding "-plugin vectorkong" to your MAME arguments e.g.
mame dkong -plugin vectorkong
or you can enable the plugin in your MAME configuration.
I've tested with the latest MAME version 0.244 and it's compatible with all MAME versions from 0.196
There may be a few things to tidy up or optimise.  Any feedback would be greatly appreciated.
** HELP NEEDED **
I'd like to see how the vectors scale up with higher resolutions.
Does any one have a super high resolution monitor?  I've tested up to 1920 x 1080 with rotated display.  I'm using opengl rendering "-video opengl" for my tests. It would be great to see screenshots at higher resolutions.
« Last Edit: May 27, 2022, 03:59:46 am by 10yard »
10yard
    • DKAFE Frontend
« Reply #36 on: May 26, 2022, 08:51:12 am »
Here's a gameplay video to show progress.
10yard
    • DKAFE Frontend
Re: Vectorising an arcade game: VectorKong is Completed
« Reply #37 on: June 02, 2022, 04:32:44 am »
In this final part,  I'll complete work on the project by adding a title screen which appears when the game starts,  tweak some of the graphical issues I encountered during testing and build a release which will be made available for download.
First up, I figure that the game needs a better title screen.  The screen would appear on start-up and have a large VECTOR KONG logo made up from flashing vectors.
The game rom was tweaked to display the title screen on launch for 4 seconds before reverting to the default screen sequence.
To action this change,  the machine code of the rom was adjusted during the game initialisation in MAME.  It's pretty neat to make rom changes this way - it's automatically done by the plugin, so no files are change and you don't have to patch anything.
The first line in code below sets the A register to 6 (title screen) instead of 1 (high score screen).
The second line maximises the time to display this screen to 255 frames.
mem:write_direct_u32(0x01ea, 0x0000063e) -- force game to start on the title screen
mem:write_direct_u16(0x07d3, 0xff3e)     -- increase timer for title screen
Next,  I'll address the graphical tweaks.  There were a few things that didn't feel right after playing through the test release a few times.
1) Hammer
The hit box of the downward smashing hammer was not nearly wide enough - compared to the original game.  I've increased the size by a few pixels and also added lines of destruction which appear as the hammer smashes hits the girder.
2) Bonus/Countdown timer
The timer needed to convey some urgency when time was running out.  I've made the vector characters turn red when the timer drops below 1000.
3) Dying Mario
I've fixed his fat head, mustache and cap when spinning around.  It just didn't look right in my original drawing.  Also,  fixed his lumpy butt and moved his pocket further up when laying on his back.  The straps on his overalls were too long when climbing too.
4) Fonts
The "I" and "II" characters were added as they are necessary for 2 player games.
The "B" character was not quite right.  I fixed it.
Here's an updated gameplay video.
I've decided to limit this project to the barrels stage.  I love how this plays and focusses on the barrels.  I may come back to revisit other stage in the future.
So for now,  the project is complete.  You can download the release from my github at https://github.com/10yard/vectorkong
I've also added Vector Kong to my Donkey Kong Arcade Frontend (DKAFE).  It's simple to set up and then you can play all of the DK hacks on Windows or Pi4 systems. More info at https://github.com/10yard/dkafe#readme
Jon
« Last Edit: June 02, 2022, 08:11:56 am by 10yard »
nitrogen_widget
« Reply #38 on: June 02, 2022, 11:52:16 am »
nice
« Reply #39 on: June 02, 2022, 05:44:06 pm »
This is nuts.  Well done, man.  Now... to get it working on a real vector monitor?
