Author Topic: Segal chassis how to connect to JAMMA  (Read 1832 times)
trick72
  • Last login:August 29, 2025, 04:00:45 am
« on: March 27, 2022, 04:01:31 am »
Hi,
I have a Segal chassis CRT bought seperately. I want to put it in a cabinet with a JAMMA interface. The wiring is the RGB, Video ground and Video Sync, so 5 wires.
The Segal chassis has a 6 pin connector (see image) labeled
R
G
B
H
H+V
V
How should I wire this to the jamma? RGB is obvious, but what about the sync and ground?
princess prin prin
  • Last login:October 23, 2025, 11:10:45 am
  • intrinsically safe
Re: Segal chassis how to connect to JAMMA
« Reply #1 on: March 27, 2022, 05:21:41 am »
It could be:
R
G
B
GND
H H+V
V
The H sync pin is usually also used for composite sync (H+V) which is the sync of jamma boards. It shouldn't be hard to check if the unlabelled pin is ground
trick72
« Reply #2 on: March 27, 2022, 06:46:34 am »
Thanks for your reply.
I tried it like this:
pin1 : R
pin2: G
pin3: B
pin4: video ground
pin5: video sync
pin6: empty
When I power on the cabinet, initially the video is not in sync. It seems "stable" (so not going left/right or up/down but "all garbled").
When I disconnect video ground pin4 and connect it again while the game is running, the screen goes perfectly in sync and displays fine all of a sudden!
However, when I power-off and power-on the game again, the image is again not in sync until I manually disconnect and reconnect video ground.
Anyone familiar with this behavior?
