Author Topic: Golden Tee 2021 HDD to SSD Cloning  (Read 7105 times)
frankrizzo2
  • Last login:August 09, 2025, 03:52:53 pm
« on: March 20, 2022, 09:58:35 pm »
I'm trying to rip my Golden Tee mechanical hard drive to an SSD drive. I'm going from a 250 gb drive down to a 240 gb drive which should be easily achievable but I'm not having much luck. I've tried using EaseUS and there cloning software and it when I install the new SSD it says that it's not a bootable drive. I've also tried to create a CHD with the mechanical drive and it creates it just fine but I get a decompression error when trying to rip it to the new drive. I have a hard drive duplicator but it won't let me rip the a drive smaller in size even though the game data is only around 50gb. What other options should I try or is there another program that works better for people? Do I use the optimize for SSD option on these? Any help is appreciated
bbegin
  • Last login:February 05, 2025, 11:36:57 pm
  • Arcade games enthusiast, bartop arcade project WIP
Re: Golden Tee 2021 HDD to SSD Cloning
« Reply #1 on: March 20, 2022, 10:15:58 pm »
I would suggest you do a complete image of the source HD drive and then, put this image to your SSD.
I suggest to use Redo Rescue, wich is a nice bootable CD, all-integrated solution:
http://redorescue.com/
Personal project:
How to make a dedicated MAME Appliance on a Raspberry Pi 4/Pi 400
https://gist.github.com/sonicprod/f5a7bb10fb9ed1cc5124766831e120c4
nipsmg
  • Last login:January 20, 2026, 10:46:56 am
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #2 on: March 23, 2022, 12:50:45 pm »
I personally have used HDD Raw Copy
  • Last login:January 26, 2026, 07:56:08 pm
« Reply #3 on: March 23, 2022, 05:17:33 pm »
I second HDD Raw Copy.
also, i have a HD dock that does standalone bit for bit cloning that has worked out pretty good and it's fast too. i can clone a 500gb sata SSD drive to another SSD, bit for bit, in under 10 mins without using a computer.
I have the older version of this...
https://www.startech.com/en-us/hdd/satdock2reu3
frankrizzo2
« Reply #4 on: March 23, 2022, 10:28:40 pm »
I've tried hdd raw copy and I'm not sure if i was unable to go to a smaller drive or what the issue was and I have a duplicator that I used for my other IT game drives without issue but I lose some data going from a 250gb down to a 240gb drive doing a 1 to 1 copy. All the other drives went so well so its frustrating that something with a very similar file structure has given me so much issue. I've been using Clonezilla and a couple other rescue disks too with mixed results. They only clone if I check the skip errors box. I'll get it one way or another
bbegin
« Reply #5 on: March 25, 2022, 11:35:58 am »
The problem when you clone from a bigger disk to a smaller one is the last partition, wich will be truncated on the destination disk.
Either:
- You shrink the last partition from your source drive just under the max capacity of your destination drive
  -OR-
a) You defrag the last partition from your source drive and make sure you have enough free space to fit your destination drive
b) You clone byte-by-byte without veritication/checks
c) You reduce the partition size of the last partition of your your destination drive
d) You shrink the filesystem of your last partition of your your destination drive
Personal project:
thelanranger
  • Last login:Today at 05:21:41 pm
« Reply #6 on: March 29, 2022, 05:34:40 pm »
Try Macrium Reflect.
https://www.macrium.com/reflectfree
Make the USB drive, the clone from the bootable environment. That should clone just about anything. It should automatically resize the partition presuming it is of a supported format.
If that does not do it, then it's likely that you would need to get a 500g SSD and do a RAW copy (where it copies bit by bit and ignores all the formatting). This should work fine though if you do RAW.
game_nerd
  • Last login:June 18, 2024, 08:38:27 pm
« Reply #7 on: April 12, 2022, 05:50:48 pm »
I think this is the way to go.
I have a somewhat similar duplicator, it's supposed to copy bit for bit without any software shenanigans.
It's worked for cloning bags, silver strike, pga tour team challenge, and several megatouch drives with no issues.
Op, just to be on the safe side, go with the same size or a slightly larger drive.
Partitions may be spaced oddly on your original drive, even though all the space isn't used up.
« Last Edit: April 12, 2022, 05:52:26 pm by game_nerd »
classicjoe72
  • Last login:October 11, 2022, 11:23:40 am
  • I want to build a Fix-It-Felix Jr.!
« Reply #8 on: April 27, 2022, 08:14:40 am »
This!  I'd like to second that CloneZillia is definitely the way to go.  I used it to clone my HydroThunder HDD to SSD and it worked like a charm.
Encryptedmind
  • Last login:June 09, 2022, 09:33:13 pm
« Reply #9 on: June 09, 2022, 09:30:51 pm »
Hey Frank did you by chance clone your drive? Im trying to do the same thing but my golden tee drive is 500Gb why i dont know cause theres maybe 75Gb worth of data on there. and Im trying to clone it to a 240Gb SSD.
F2HRBALL
  • Last login:December 13, 2023, 02:43:13 pm
« Reply #10 on: December 02, 2023, 07:17:16 am »
I just cloned my drive to SSD.
Clonezilla - failed
EaseUS - failed
HDD Raw Copy Tool - 100% worked
