Author Topic: Ultimarc Spintrak Rotary Control - Lock Nut Size  (Read 3465 times)
brakertech
  • Last login:March 04, 2022, 11:20:33 pm
« on: March 02, 2022, 02:16:59 pm »
Does anyone know the proper size for a replacement nut for the Ultimarc Spintrak Rotary Control?
I lost the gray nut and am not sure where to find a replacement (or what size I should purchase).
The diagram on the manufacturer site says it is 28mm, however I tried a 28mm nylon nut for a Happ button and it screwed on for a couple threads and then wouldn't go any further.
I would appreciate any advice.
bollwerk
  • Last login:November 20, 2023, 08:27:52 pm
Re: Ultimarc Spintrak Rotary Control - Lock Nut Size
« Reply #1 on: March 04, 2022, 09:36:42 pm »
Maybe this is a dumb question, but did you contact Andy at Ultimarc? He usually responds within a day or so, based on my experience.
andy@ultimarc.com
brakertech
« Reply #2 on: March 04, 2022, 11:17:01 pm »
I contacted Andy and he got back to me right away.  He is shipping me a replacement.
Great support!
  • Last login:Today at 02:27:03 pm
« Reply #3 on: March 04, 2022, 11:29:08 pm »
It's probably a difference between Imperial and Metric thread sizes.
- The thread pitch on a Happ button is 13 threads per inch ==> 1.9538mm/thread.
- An M28x1.5 nut is 1.5mm/thread.
- An M28x2 nut is 2mm/thread.
If you have a metric thread pitch gauge, use that to verify the thread pitch on the SpinTrak.
If you don't have a metric thread pitch gauge, use calipers to measure the pitch.
- Set the calipers to 6mm and measure the SpinTrak threads.
- If there are 3 threads between the jaw points, it is 2mm pitch.
- If there are 4 threads between the jaw points, it is 1.5mm pitch.
If you have access to a 3d printer, you can make a custom nut using OpenSCAD and a thread library like I did for this rotary encoder mount.
EDIT: I'm glad Andy is shipping you a replacement.   :cheers:
Fursphere
  • Last login:Today at 06:14:39 pm
« Reply #4 on: March 08, 2022, 07:24:12 pm »
Lol, the thread pitch gauge or the calipers will cost more than a replacement spinner!   :)
Based on the design of the lock nut and how it scraps the wires very tightly on the Ultimarc SpinTrak - I've been considering machining a new nut, then splitting it with screws.   So it can be installed / removed without scraping the wires.   More out of fun than necessity.
« Reply #5 on: March 08, 2022, 09:12:16 pm »
Fursphere
« Reply #6 on: March 09, 2022, 01:34:11 am »
For the sake of argument, you showed a picture of Mitutoyo calipers, not harbor freight junk.  :)
Thread pitch gauges aren't too bad.
« Reply #7 on: March 09, 2022, 04:15:13 am »
Fair enough.
I just picked a picture that showed the tool so readers wouldn't think I was referring to some other type of calipers like these.   ;)
Of course, if you want really cheap, junky, pain-in-your-keyster calipers, get the plastic vernier ones.*   >:D   :puke   :duckhunt
https://www.harborfreight.com/6-in-utility-caliper-63664.html
* Friends don't let friends buy vernier calipers.
Fursphere
« Reply #8 on: March 09, 2022, 10:46:49 am »
*shudder*
No, just no.
Fursphere
« Reply #9 on: March 10, 2022, 07:37:06 pm »
For reference....
 I broke out the Mitutoyo thread pitch gauge set.   Its a 16 TPI thread.   Not metric, which I thought was interesting.
