Author Topic: I-pac gone nuts  (Read 1477 times)
Psycon
  • Last login:February 05, 2022, 06:29:48 am
I-pac gone nuts
« on: February 04, 2022, 05:03:54 pm »
Hi all.
I have an ipac which was working fine. I did a fresh install of winipac and since then my I-pac has gone loopy. If you plug it into the pc with no wires attached it sends out a constant key press of 5 like this 555555555 ect. It will also start to open Google chrome constantly until I unplug it. Any ideas if this can be fixed?
Psycon
Re: I-pac gone nuts
« Reply #1 on: February 05, 2022, 05:41:12 am »
OK I have now made some progress. The constant output of keystrokes has now stopped but in order for the winipac software to see the board I have to plug in the board first then start the software. Now for some reason when I change anything in the software the program locks up. I was getting a fashing light but it's now solid again. Any ideas?
Psycon
Re: I-pac gone nuts
« Reply #2 on: February 05, 2022, 05:53:45 am »
Forget that it's now spamming kkkkkkkkk! I think the board has a fault as even though when I can get the software to change one of the inputs, it says board updated but when I then unplug it and load it again the change doesn't stay 😔
« Last Edit: February 05, 2022, 06:30:04 am by Psycon »
