Author Topic: External speakers on a Rowe CD100E  (Read 3368 times)
RockOut
  • Last login:February 03, 2022, 03:57:36 pm
« on: February 02, 2022, 10:52:28 pm »
I’ve got a CD100E with the internal speakers attached to E6.  I’d like to add a pair of 8 ohm external speakers(Klipsch KHO-7) at around the same volume or slightly less.  I attached them to E5 but they can barely be heard.
Are the internal speakers 4 or 8 ohm?
If they’re 8 ohms then the internal speakers are only taking 32 watts per side (L,R).
Can I add the external speakers in parallel with the internal speakers on E6 which would be 64 watts?
Alternatively, can I move the internal speakers to E7 then put the external speakers on E6 which would be 89 watts per side?
  • Last login:March 08, 2026, 07:17:46 pm
Re: External speakers on a Rowe CD100E
« Reply #1 on: February 03, 2022, 02:00:07 pm »
since the speakers you are adding onto the jukebox are 8 ohms, you can just go ahead and add them to to E7 tap. if they where 6 or 4 ohms you'd want to go a little lower on E6 or E5.
RockOut
« Reply #2 on: February 03, 2022, 03:58:24 pm »
I took your advice and it sounds great.  Oddly enough, the volume is right level.  My primary concern was over loading the amp without knowing the ohm rating of the in box speakers.
« Reply #3 on: February 04, 2022, 02:40:41 pm »
the worksheets in the manuals where you have to calculate the speaker watt ratings and whatnot, where done up in a time where people didn't really understand the dynamics of an audio system. We've basically come to a new (and correct) understanding that we need to have a minimum speaker load applied to an amp to keep things from going haywire and blowing amps, and the load requirements of an amplifier are what actually determine if it can be run or not... not how may watts are attached to it.
you could in theory wire up hundreds of speakers to a single amp, provided you do it the correct way.
