Author Topic: My Wico leaf joy - It finallly arrived, but....  (Read 3008 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« on: February 27, 2004, 07:54:36 pm »
The parts list for the "2-Way, 4-Way, 8-Way Replacement Stick" calls up two switch actuators.
One is used for 2 and 8 way use (.600" diameter), and the other is used for 4-way use (.500" diameter)
I only received the .600" with my stick.
The model number is 15-9653. Should I have received both?
Where can I get a .500" ?
This is probably something that I can make, but I was just wondering.....
Thanks in advance.
%$#@!&* machine took my quarter!
spidermonkey
  • Bombjack junkie
Re:My Wico leaf joy - It finallly arrived, but....
« Reply #1 on: February 28, 2004, 12:01:01 pm »
They never come with both. :(  Mine didn't either. The instruction sheet is misleading as I thought I was missing one too. Talk about cheap >:(. I mean how much could it cost to throw in both actuators ? Maybe another 3 cents ? ::)
"Sinistar has bad breath"
Oldskool
« Reply #2 on: February 28, 2004, 09:19:42 pm »
Not even...... :(
Tailgunner
« Reply #3 on: February 28, 2004, 11:11:59 pm »
I'd be hard pressed to believe Wico sold these for more than $5 each when new, so I'd likely attribute them leaving out the other actuator up to penny pinching. Then again, the other actuator is useless for a given stick, so there would be no good reason to include it as it'd likely just be tossed in the trash by the service techs.
If you can scare up a Wico rebuild kit, they come with both actuators.
HagHore
  • Last login:October 24, 2007, 02:24:00 pm
  • Game Over Man, Game Over!
« Reply #4 on: February 29, 2004, 11:22:18 am »
Are you going to be using yours for 4-way action only?  If so, I have the .5 actuator but I need the .6.  If you only need 4-way action then I'd be more than happy to trade with you.
We're on an express elevator to Hell! Goin' down!
Oldskool
« Reply #5 on: February 29, 2004, 12:20:41 pm »
Excellent.
A PM is on the way....
