Author Topic: Guncon2 and Guncon3 windows driver  (Read 57034 times)
sonik
  • Last login:May 21, 2025, 05:44:34 pm
« on: January 25, 2022, 07:05:37 am »
I've made POC windows drivers for the Guncon2 and Guncon3.
Works on Windows 10 and does not requires disabling driver signature.
Guncon2 does not have the "rolling x" problem with this driver.
It's based on the research and documentation done by beardypig.
For the guncon2 to work correctly it's desirable to have a screen flasher and I have no idea how to do this.
If any dev wants to jump in and help please let me know.
Project is here:
https://github.com/sonik-br/GunconUSB
Inside there's links for the original linux versions by beardypig.
Titchgamer
Re: Guncon2 and Guncon3 windows driver
« Reply #1 on: January 26, 2022, 02:52:16 am »
Cool :)
bandicoot
  • Last login:Yesterday at 03:46:48 am
« Reply #2 on: January 26, 2022, 12:12:39 pm »
 :applaud: :applaud: :applaud: :applaud: :applaud:
phasermaniac
  • Last login:June 10, 2025, 09:39:41 am
« Reply #3 on: January 26, 2022, 01:30:57 pm »
Nice! some questions about the guncon2 driver:
- Can two guns be used for 2 player games?
- Does it work with games' native flashing? I remeber you got this working with the guncon1.
- The flasher, you might want to talk to burn_654. He made a flasher years ago, and a circuit that sends a key instead of trigger, some delay, and trigger.
sonik
« Reply #4 on: January 26, 2022, 03:43:28 pm »
It does work with games that have native flasher like time crisis.
Driver made for one gun only Might be possible to add 2 player mode in the future.
I'm currently not working on this driver anymore as without a flasher its impossible to play the majority of games.
I tested the linux driver and it works good!
And since it's a real kernel driver so it might just work with any number of guncons.
AMG KC
  • Last login:June 29, 2022, 05:33:52 am
« Reply #5 on: March 17, 2022, 10:51:43 am »
This is fantastic, exactly what i was hoping to find one day!!
I still have loads of CRTs and loads of light guns, i will be dead long before i have to waste my time with sensor bar or Sinden style guns.
MK3FANATIC
  • Last login:November 08, 2025, 08:56:50 am
« Reply #6 on: March 19, 2022, 08:03:30 am »
I have a pc with windows 10 and crt emudriver connected to a crt tv by a vga-component video converter. I also have a pistol compatible with guncon 1 and 2. I would like to try to test this driver. Could someone give a mini tutorial for a newbie on how to do it? Which emulator should I use, if I only need to connect the pistol's usb cable, if I need any more applications...
sonik
« Reply #7 on: March 24, 2022, 10:27:34 am »
Hi. I tried to build a new version but it not worked. It depends on Tetherscript's virtual joystick and mouse, and it have changed. I need to fix the code.
I will try to do this over the coming weeks.
And keep in mind that it's not a polished application/driver.
sonik
« Reply #8 on: March 28, 2022, 05:21:59 pm »
If you want to test.
Download and install vjoy from https://sourceforge.net/projects/vjoystick/
Go to github download and install my guncon2 driver.
Use the attached app. It requires dot net framework 4.5.
GustavoALara
  • Last login:October 30, 2025, 07:36:04 am
« Reply #9 on: May 02, 2022, 01:09:02 pm »
Hi Sonik,
A friend of mine and me are testing your driver and we have a couple of questions..
We've installed vJoy, WinUSB drivers and the theter driver.  After the installation of the drivers we run your tool and the Guncon2 moves the mouse pointer and we can check the guncon2 buttons on your tool, but outside your tool, the lightgun buttons don't work as mouse buttons/key strokes or gamepad buttons.
We can see on the control panel a Guncon and a Vjoy device but neither of those are gamepads
Is there any step that we forgot to do? What is the correct steps to install your driver?
In another hand we detect in dark zones of the CRT TV the driver works worst.. is this correct?
Thanks in advanced
shiryu55
  • Last login:April 18, 2023, 03:46:44 am
« Reply #10 on: May 02, 2022, 04:37:20 pm »
I am the other interested party, it only remains to add that guncon2 appears in the device panel as if the driver was not installed correctly.
It appears with the typical icon as if it was not recognized by Windows.
A greeting from Spain
sonik
« Reply #11 on: May 06, 2022, 04:05:31 pm »
@GustavoALara
The tool must be kept open for the mouse to move.
And yes, the gun can't detect darker areas. CRT lightgun games uses brighter images or does a "fast white flash" when you pull the trigger, so the gun can detect.
@shiryu55
Installed the driver from github?
psakhis
  • Last login:September 24, 2024, 11:54:25 am
« Reply #12 on: November 14, 2022, 03:40:30 am »
Hi,
Anyone knows if this driver works on W7?
EDIT: works but it disconnects at random. I don't understand calibration tool at all...
« Last Edit: November 20, 2022, 10:32:49 am by psakhis »
sonik
« Reply #13 on: November 26, 2022, 12:40:12 pm »
GC2 or GC3?
I remember to get some GC2 disconnects if gun is too close to the crt.
Can't figure why this happens and can't fix.
phasermaniac
« Reply #14 on: November 27, 2022, 06:33:49 am »
Hi!
I had some disconnection problems years ago, although my problem was not with the distance to the crt, but the connection itself. I don't remeber what I did to solve it as it was ages ago, but @Foxhole, who seems to use a configuration similar to mine, messed with it more recently:
http://forum.arcadecontrols.com/index.php/topic,159617.0.html
I have a EMS USB 2 which converts the guncon1 to guncon 2, but i'm having issues with it. It works for 3-5 seconds and then the gun stops working, even the buttons, though the led on the converter itself is still on. It may be due to how i have my sync wired up though.
Enabled csync on vmm, removed vsync wire, removed resistor, connected everything back, connected the ems usb2 converter, g-con 45 now works.
Maybe this helps
psakhis
« Reply #15 on: January 12, 2023, 01:42:51 pm »
My disconnections are with GC2.
If i change sync, probably i lost video signal on tv (sync vs csync)
psakhis
« Reply #16 on: January 18, 2023, 01:21:20 pm »
It's possible a guncon2 usb app with some logger?
I'm pretty sure some exception occurs inside because i can stop and start without any problem but when i interact with some other app device is gone randomly.
If i re-enable device, works again.
sonik
« Reply #17 on: January 19, 2023, 07:07:42 am »
So... Tetherscript's HID driver kit has been discontinued.
Current version might still be able to work on older windows but will eventually stop working on recent windows versions.
Might be a better option to switch to linux or a rpi4 (and use rgbpi).
flybynight
  • Last login:July 12, 2025, 08:20:47 pm
« Reply #18 on: January 21, 2023, 06:22:01 am »
That is sad news indeed but I wouldn't give up sonik!
The developer said you can install controlmyjoystick free trial to get the drivers after the cert expires on the free one: https://tetherscript.com/controlmyjoystick-download/
You could also enable windows test mode to allow the the drivers be installed with the bad cert.
I wonder too will it just be a case of setting your PC time/date back to Jan 2023 before installing?
In the meantime it's recommended to install this now before the driver cert expires.
psakhis
« Reply #19 on: January 23, 2023, 02:26:32 pm »
If anyone would to try it, based on @sonik driver.
https://github.com/psakhis/guncon2
phasermaniac
« Reply #20 on: January 23, 2023, 04:44:38 pm »
I will! But give me time I have an exam sunday.
I suppose by now it supports two lightguns in joystick mode right?
Gràcies
psakhis
« Reply #21 on: January 24, 2023, 05:39:24 am »
Not yet.
What bothers to me is i'm saying ~30/40ms of delay between emulator increase brightness and guncon reads a good x,y coord. I discarded vjoy, i verified emulator see triggers after 3ms vjoy is updated.
This not happens on Linux...and in fact, for example in emu4crt i will need increase input lag for this can work but is too weird for me.
EDIT: LOL, after adapted daemon to async reading values with the same results, now i see is emu4crt on Windows than blit slower than Linux...if i disable vsync works so fast.
Sort al exàmen.
« Last Edit: January 24, 2023, 08:18:19 am by psakhis »
phasermaniac
« Reply #22 on: February 03, 2023, 04:35:15 am »
Hi! now I have some time to test.
I have read instructions here https://github.com/psakhis/guncon2 and I don't fully understand:
1. Install VJoy - https://sourceforge.net/projects/vjoystick/
2. Install GunCon2 Driver - https://github.com/sonik-br/GunconUSB
But I suppose I have to install your Guncon2_winusb_driver_installer.7z, not sonik's one, right?
I suppose I don't have to install TetherScript's "HID Virtual Driver Kit", only vjoy and your driver, right?
Later you say to run daemon But what is it?
thanks
psakhis
« Reply #23 on: February 03, 2023, 07:29:09 am »
Hi,
1) You need winusb driver. This is sonik driver. aka Guncon2_winusb_driver_installer.7z
2) You need install vJoy
3) After that it's all about installing. Your windows recognize guncon2 as device and you have vjoy for virtual joysticks
My "console" or "daemon" is needed for comunicate winusb driver to vjoy. Just you need to run.exe for this happens; and your guncon2 will be attached to vjoy device.
phasermaniac
« Reply #24 on: February 08, 2023, 05:18:16 pm »
Working nice thanks!
I have send you two pms.
psakhis
« Reply #25 on: February 11, 2023, 03:48:33 pm »
New version released:
 - Added internal flasher
 - Mouse mode works without pass resolution
Jonathan Smith
  • Last login:January 28, 2025, 10:00:36 am
« Reply #26 on: February 11, 2023, 09:33:20 pm »
I got the driver working for guncon 2 but it doesn't work for Guncon 3. Did I miss a step or is there a separate app for the guncon 3?
Jonathan Smith
« Reply #27 on: February 12, 2023, 07:58:37 am »
Does the updated version of the guncon 2 driver allow you to switch on or off the white screen flash in case the game has a native white flash?
« Last Edit: February 12, 2023, 08:01:43 am by Jonathan Smith »
psakhis
« Reply #28 on: February 16, 2023, 03:29:46 pm »
Hi,
Yes, internal flasher is optional. I will do some optimized version of this and another options like input delay for shooting always with brightness.
This don't work with GunCon3, i don't have one for test it. With some minor changes the same driver can work.
bionyx
  • Last login:March 09, 2023, 08:32:15 pm
« Reply #29 on: March 09, 2023, 07:58:20 pm »
Whenever I use the Guncon2USB.exe, it works for about 20 seconds, then stops recognizing the gun, and I have to restart the program. Is there anything to fix this?
« Last Edit: March 09, 2023, 08:26:45 pm by bionyx »
psakhis
« Reply #30 on: March 10, 2023, 04:23:41 pm »
@bionyx, it's fixed. Just follow instructions on github for install driver and run daemon.
SpongeDan
  • Last login:July 19, 2023, 10:30:36 pm
« Reply #31 on: March 12, 2023, 07:35:36 pm »
Never mind; please delete this message.
« Last Edit: March 13, 2023, 03:54:52 am by SpongeDan »
mckrauser
  • Last login:March 22, 2023, 06:48:24 am
« Reply #32 on: March 22, 2023, 06:48:44 am »
Is the driver for Guncon 3 functional? Is there tutorial? I currently use a couple to play PSOne on FPGA and I would love to use it for the same on PC. Thank you.
psakhis
« Reply #33 on: March 27, 2023, 01:04:00 pm »
Python daemon it's only for GunCon2, although will be easy adapt to GunCon3 i don't have this gun to testing.
Are you tested @Sonik-br's driver and console for GunCon3?
pcnimdock
  • Last login:April 16, 2023, 03:36:10 pm
« Reply #34 on: April 02, 2023, 08:52:42 pm »
I modified the guncon2 version for guncon3 for linux
https://github.com/pcnimdock/guncon3_dkms
Also I modified pcsx2 to accept lightgun in joystick mode.
https://github.com/pcnimdock/pcsx2/releases/tag/v0.0.3
phasermaniac
« Reply #35 on: April 03, 2023, 09:40:57 am »
Why is this not added to the nightly versions?
If I create an Input profile, to load it with the pergame config, it seems to not apply the "guncon2_use_gamepad = true". This happens to you or It's my mistake?
pcnimdock
« Reply #36 on: April 03, 2023, 12:23:48 pm »
I do a pull request but they don't like it.
It's my mistake, at now it's only apply to shared input profile.
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
« Reply #37 on: April 13, 2023, 10:43:23 am »
I'm getting back into the swing of some lightgun projects (I had been on and off working on the Topguncon project and it's flasher for some time) so I had to check out sonik-br's driver with psakhis's daemon.
I'm getting some really good results with it so far. A name-brand guncon2 is working without rolling-x. The flasher works well, and even without driver calibration the shots are placing pretty consistently for me. This is an exciting time to be tinkering with crt guns!  :applaud:
It also pairs well with the modified pcsx2 that pcnimdock has just posted! I recorded a quick demo on Time Crisis 2. I was able to bind the sdl joystick axes to the left and right axes in the Guncon controller config, though I did have to go and edit the pcsx.ini afterwards as it was pretty sensitive and picking up multiple axes at once. My guncon config section looks like this:
Code: [Select]
[USB1]
Type = guncon2
guncon2_Recalibrate = Keyboard/Z
guncon2_Select = SDL-2/X
guncon2_Start = SDL-2/B
guncon2_C = SDL-2/DPadUp
guncon2_custom_config = false
guncon2_A = SDL-2/Y
guncon2_AimX_L = SDL-2/-LeftX
guncon2_AimX_R = SDL-2/+LeftX
guncon2_AimY_D = SDL-2/+LeftY
guncon2_screen_height = 480
guncon2_center_y = 240
guncon2_AimY_U = SDL-2/-LeftY
guncon2_TriggerDeadzone = 0
guncon2_ShootOffscreen = Keyboard/X
guncon2_Trigger = SDL-2/A
Here's a demo - ignore the first couple shots being a bit off - had to adjust my hands in recording. In play it was quite snappy. My guncon psakhis daemon settings were:
Code: [Select]
run -f=3 -d=0In my case I was able to use zero input delay after the flash (d=0) but I feel like other games/emulators you need this. From my own experimentation with Topguncon this was needed for some games if the flash was happening 'after' the input.
https://drive.google.com/file/d/1Kd42jOZTnRInbAxcSnXc10TkSy6uqg1H/view
lllll44
  • Last login:August 09, 2025, 10:29:49 am
« Reply #38 on: May 06, 2023, 06:59:59 pm »
can the guncon3 driver work with rpcs3? will be very cool with time crisis 4 standalone version.
burn_654
« Reply #39 on: June 01, 2023, 06:27:48 pm »
Apologies - on my previous post the video of Time Crisis 2 (PCSX2) running with this driver and daemon was set to private - should be viewable if anyone was curious.
