Author Topic: Hooking dual mono sound via JAMMA - ground via daisy chain?  (Read 1690 times)
USSCrazybat
  • Last login:February 26, 2023, 09:33:28 am
  • I can't build controls for s**t!
« on: January 22, 2022, 04:08:27 pm »
Hi all,
Doing a small cocktail cab build atm, currently hooking audio up but am unsure about something. Pin 10 on the harness is speaker, parts side is white w/black strip and solder side is pure white. As I understand it these are Speaker + and Speaker -. I'm using dual basic 5w speakers, one speaker is using the Speaker+ wire and the other is using the Speaker- wire whilst the negative terminals on each are hooked to the ground daisy chains underneath each player's control panel. Is this correct/safe/sensible?
