Author Topic: GRS DOT PUSH PULL SPINNER  (Read 4221 times)
BUCKETHEAD
  • Last login:April 04, 2024, 07:31:52 pm
  • Don't hate the player .... Hate the Game
« on: January 22, 2022, 10:22:43 am »
I just purchased the GRS DOT PUSH PULL SPINNER.
So far it is great !  Very easy to install.
My only gripe I wish the USB cable was longer to drop down in the bottom of my cab to my PC. But I made it work.
I was playing Discs of Tron last night and on the Push Pull Levels.
I could only seem to aim down.
Anyone have any experience with this spinner ?
Does is work for DOT right out of the box?
Or do I need to configure something in Mame ?
Thanks so much !
SORHP
  • Last login:January 18, 2026, 03:57:45 pm
Re: GRS DOT PUSH PULL SPINNER
« Reply #1 on: January 22, 2022, 11:26:59 am »
You probably need to go into mame settings for dot and set the controls up
Games: Super Punch Out, Fix It Felix Jr, DK, DKjr, DK3, PC10, UMK3, TRON, MS-Pac, Pac, Centipede (2x), Robotron, Galaga, Space Invaders, Street Fighter 2 CE, X-Men vs SF, BuckHunter HD, 2X Custom Vewlix, Custom Nintendo VS 3/4, Atomiswave
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« Reply #2 on: January 22, 2022, 02:45:06 pm »
How big is this? Does it fit into a standard arcade button hole?
BUCKETHEAD
« Reply #3 on: January 22, 2022, 03:48:05 pm »
Yes button hole size.
It fit in the existing spinner hole of my Tron cab.
My problem is in the chaos gameplay of DOT I can't tell if the aim / push pull is functioning correctly
  • Online Online
  • Last login:Today at 12:48:14 am
« Reply #4 on: January 22, 2022, 08:51:35 pm »
Pretty sure the push and pull functions are left and right mouse buttons.
- You can confirm if they are functioning in Windows or just remap the "Aim Down" and "Aim Up" DOT controls in MAME.
BUCKETHEAD
« Reply #5 on: January 23, 2022, 04:01:10 pm »
Ok so I made it back to the push pull levels here's what's definitely going on.  PULL UP makes the aim do down.  PUSH DOWN throws discs just like the trigger, and the joystick makes the aim go up every time I move Tron forward.
bobbyb13
  • Last login:February 21, 2026, 01:34:49 am
« Reply #6 on: January 23, 2022, 06:12:16 pm »
Sounds like a mapping issue.
Have you tried to hit tab with the game running and see what is going on in there?
BUCKETHEAD
« Reply #7 on: January 24, 2022, 06:21:31 am »
Honestly i haven't fooled with Mame in years far as button mapping anyway.  I had forgotten it was that easy. I am going to try it today.
Thanks !
BUCKETHEAD
« Reply #8 on: January 24, 2022, 02:38:18 pm »
Well... apparently it isn't that easy.  I got into the settings and tried to assign the push pull to buttons 4 and 5. No Dice !  Won't take them. 😑
bobbyb13
« Reply #9 on: January 24, 2022, 11:46:04 pm »
Damn.
I was hoping it would be something simple for you.
Maybe that spinner is trying to use moust button presses and it is confusing things for what you want?
Must be some setup bit somewhere that dictates what is what.
negative1
  • Last login:February 28, 2026, 07:19:30 pm
« Reply #10 on: January 30, 2022, 07:28:30 pm »
detailed review of tron joystick and spinner from Glen,
it comes with a balltop joystick too
later
-1
BUCKETHEAD
« Reply #11 on: February 05, 2022, 10:43:00 pm »
I finally got the spinner to work for me in Discs of Tron (push pull feature) I originally had a pentium 3 running XP in my cabinet. It worked great for what I was using it for.
Until I purchased the GRS DOT SPINNER. So I ditched that setup... I had a busted screen laptop lying around  so I decased it and mounted it to a cutting board. I installed windows 10 and a newer version of Mame.
Now the Spinner works perfectly with Discs of Tron.
But it was still a pain in the ass to map the Aim up and Aim down in Discs of Tron.  Actually it never would, I had to use a regular mouse to get the mapping done.
My thoughts..... The Spinner is great and heavy duty!
It works well when you get it going. For me that was the hard part.
At least the (Push Pull Feature)
« Last Edit: February 06, 2022, 12:09:00 am by BUCKETHEAD »
