Author Topic: Groovymame attract mode resolution error  (Read 4043 times)
Jodannar
  • Last login:January 09, 2023, 01:02:09 am
« on: January 03, 2022, 04:56:20 am »
Hi all. I’m relatively new to all of this crt setup at 15khz and I have made an error when using groovymame on a setup I purchased. I have altered the resolution within groovymame to a resolution that the monitor does not support, as such I get a garbled desynched mess in attract mode. If I launch into a game, the resolution switches and is correct through mame, I only have the issue on boot into attract mode. Returning from mame to attract mode the resolution swaps back to what was set and I get desync. If I exit attract mode.. I think it’s kicking me back to the groovymame setup config window as I have some blue garbled mess, but I can’t navigate it to correct any issues.
 I have tried connecting an lcd but that forces the gpu into a resolution it can handle and then I have the inverse problem.  When using an lcd if I try to exit attract mode it is not booting me out to the groovymame setup as it used to. Any assistance please?
Jodannar
Re: Groovymame attract mode resolution error
« Reply #1 on: January 03, 2022, 05:05:18 am »
Additional information. Running the latest groovymame version through the inbuilt update. Linux system.
buttersoft
  • Last login:Today at 12:00:44 am
  • Is running at 15kHz
« Reply #2 on: January 03, 2022, 05:29:46 pm »
Does GM on linux use the ini files? Try deleting default.ini, if such a thing  exists. But also open MAME.ini and see if there's a weird resolution set somewhere, i guess?
Substring
  • Last login:November 23, 2025, 01:16:00 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
« Reply #3 on: January 03, 2022, 05:59:47 pm »
I'm not sure I understand good the issue : GM runs great, but not AM ?
Are you, by any chance, using GroovyArcade ?
Jodannar
« Reply #4 on: January 03, 2022, 07:06:19 pm »
Apoliogies, yes. It is a GroovyArcade distribution being used as the OS that has the setting altered within it. As stated, quite new to this and incorrectly stated the component in error.
Substring
« Reply #5 on: January 04, 2022, 04:35:25 am »
can you give me the output of uname -a please ? I wish you have my version of GroovyArcade, and not the old unmaintained one ...
Jodannar
« Reply #6 on: January 04, 2022, 04:46:47 am »
Will do once I can ssh into the machine or get an output of a command line onto an lcd monitor in the coming days.
Jodannar
« Reply #7 on: January 05, 2022, 05:31:40 pm »
This has been resolved by sting into the machine and re-configuring the resolution through gasetup.
