Author Topic: PI 1541  (Read 7127 times)
nitrogen_widget
PI 1541
« on: December 17, 2021, 07:57:39 pm »
Coolest thing i've used in a while.
I got the pi zero model for my vic 20.
Here is the site in case you havn't heard of it.
https://cbm-pi1541.firebaseapp.com/
i bought my hat from china.
followed the directions and it worked.
eventually.
there are two types of hardware and i had selected the wrong type in the config.
it uses the rom for the 1541 drive and a few other files from VICE emulator.
it's just really cool.
you use button on the device to navigate to vic 20 .d64 or .prg files, select the image which is the same as loading a disk into the drive (including slowness).
then type load"*",8,1 into the vic.
after it's done type run.
just like the c64.
now i did buy the pentultimate cartridge which gives you various ram options from 8k to 35k for the home brew games which there are a few out there.
that cartridge also comes with some games.
never had a vic20, my cousin did.
i had the ti99.
i'm def. getting one of these for my c64 once i get it repaired and i'm getting the one with the fast load cartridge built in.
danny_galaga
  • Last login:February 16, 2026, 07:16:44 pm
    • dans cocktail lounge
Re: PI 1541
« Reply #1 on: December 23, 2021, 04:45:02 pm »
Sounds good. I have one of those earlier disk drive emulators. So long ago I can't remember what it is. It's very handy but some multi disk games won't work. In particular, you can't save in Elite, which is what I was playing the most of.
So does the Pi version have this function?
nitrogen_widget
Re: PI 1541
« Reply #2 on: December 26, 2021, 01:01:13 pm »
i'm not there yet.
the previous type SD2IEC might of had those issues before but it appears to of been fixed?
from what i've read, some games need to be run in VICE first to create a save disk image for the pi1541.
Wasteland on the c64 is one example.
i'll try Elite on the vic and report back though.
danny_galaga
Re: PI 1541
« Reply #3 on: December 29, 2021, 12:16:09 am »
That's it- SD2IEC . Good little unit, very happy with it other than I can't do Elite saves
swofra
  • Last login:September 05, 2022, 04:58:47 am
Re: PI 1541
« Reply #4 on: January 23, 2022, 09:45:25 am »
Ahh, Elite.  Looked like a great game but i could never figure out docking and always crashed.
nitrogen_widget
Re: PI 1541
« Reply #5 on: January 26, 2022, 07:53:42 pm »
Elite is not on the vic20.
It's on the c64.
I have one of those but the text flashes all kinds of colors then the screen goes black.
I have a new PSU for it and some ram chips and the PLA plus sockets.
just need time to work on it.
danny_galaga
Re: PI 1541
« Reply #6 on: March 10, 2022, 06:05:46 pm »
It's on the c64.
Oh ha! I saw 1541 and just thought C64 without reading you're first post attentively 😄
Re: PI 1541
« Reply #7 on: March 10, 2022, 09:48:55 pm »
I have a pi 1541 for my c64 (combination Pi/Epyx fastloader with the micro LCD screen), but things are not set up at the moment. I'd be happy to test for you when I do pull it out, but it will be some time before I do. (House renovations)
Most games are compatible, it is (Almost completely) a cycle count accurate emulation of a 1541.
One small mod I have for mine is swapping out the scroll buttons for a pot to make my library easier to navigate. I'll have to also need to 3d print a new case to accommodate a dial.
Not mine, but the version I have:
nitrogen_widget
Re: PI 1541
« Reply #8 on: March 11, 2022, 07:37:45 pm »
I have this also.
but i have no fricken clue where it is.  :banghead:
I hate when i do that.
however the one i use for the vic can pull double duty for the c64 once i get it up and running.
