Author Topic: Golden Tee 2012 PSU Fried  (Read 4669 times)
efletch3
  • Last login:December 16, 2021, 11:47:31 am
« on: December 11, 2021, 09:14:48 pm »
Buddy and I are trying to get a 2012 Golden Tee up and running. Previous owner had it sitting in his garage for years and said it just needed a new power supply.  Buddy ordered a Power Pro CD-300BE and put it in. Marquee lights up, fans start, but nothing loading. I came over to see if I could help, looked over the boards (everything dusty, but seemed ok), checked connectors, CMOS battery was reading 2.6V so replaced it since it had been sitting for many years, and then plugged the PSU back in after making sure good power was coming into the console.  Turned it on and CPU fan began to spin slowed down and stopped, then PSU sparked and died.  Yes, we are total amateurs.
Could this be a bad PSU issue?  Could faulty fans do this?  Any advice would be helpful.
Thanks,
Ely
smalltownguy
  • Last login:October 07, 2025, 12:45:27 pm
Re: Golden Tee 2012 PSU Fried
« Reply #1 on: January 05, 2022, 11:56:07 am »
I would be interested in buying this whole game from you if it's for sale.
« Reply #2 on: January 05, 2022, 04:21:00 pm »
That spark you saw might have been the internal fuse in the PSU blowing. That is best case anyway. I would crack it open and check/replace the fuse inside that PSU with a same rated replacement.
Given that you were warned it was PSU issue and you quickly blew out a new one, it sounds more like something is quickly overloading the PSU, and it might be the motherboard itself, or a component on it. I would think a even a good fan could cause problems if someone connected it to the wrong pins. I would just take things one by one and troubleshoot it as a PC, ignore any arcade machine elements.
Visually look over the motherboard and unplug every component to protect as much of the machine to help isolate what caused the problem and protect your other components as you work through it. Disconnect the hard drive, the ram, the usb connections, security chip, VGA connections the video card, etc. See if you can get a beep and sign of life, then one-by-one power down and try adding in a component. You should also be able to just plug in an old LCD as you get the main system to boot, so you don't have to juggle the element of the CRT at the same time.
