Author Topic: Second monitor active, so groovymame does not start  (Read 4045 times)
Lexmaul
  • Last login:January 01, 2022, 09:44:50 am
« on: December 01, 2021, 08:07:55 am »
Hi there,
i have a problem that Groovymame only starts when I have the LCD monitor on. If I unplug it, Windows can still be seen on the CRT, but it does not start. What did I do wrong or what could I change?
Thank you for help and best regards
Sebastian
« Last Edit: December 01, 2021, 08:59:31 am by Lexmaul »
Lexmaul
Re: Second monitor active, so groovymame does not start
« Reply #1 on: December 01, 2021, 04:31:34 pm »
Reinstalled again, unfortunately it just doesn't work. If I start mame.exe - v via the console, then the application starts ... I just don't understand it.
SOLVED: In addition, many games are pressed to 1/3 - I'm slowly desperate :(
-> I installed DirectX and all games are in full screen - a littöe step :)
« Last Edit: December 01, 2021, 04:54:14 pm by Lexmaul »
Lexmaul
« Reply #2 on: December 01, 2021, 06:30:45 pm »
SOLVED: the soundcard was disabled...
 :banghead: :cry: :laugh2:
