Author Topic: Sega cushion clips  (Read 6811 times)
fablog
  • Last login:January 04, 2026, 04:27:15 pm
Sega cushion clips
« on: November 28, 2021, 10:42:28 am »
Hi guys,
Do you know where I could buy Sega cushion clips for a sega daytona/nascar/etc... for cheap in Canada? The reference number is 280-K02529-WX.
I'm wondering if an alternative exists!?
  • Last login:January 26, 2026, 07:56:08 pm
Re: Sega cushion clips
« Reply #1 on: November 28, 2021, 02:47:26 pm »
yeah they are plastic lugs commonly used in automotive. take a look at your local autoparts store. they often have several sizes/colors to choose from. sometimes called plastic lugs or automotive clips...sometimes fender clips.
« Last Edit: November 28, 2021, 02:49:01 pm by lilshawn »
fablog
« Reply #2 on: November 28, 2021, 04:13:09 pm »
Thanks lilshawn!
Envoyé de mon LEX722 en utilisant Tapatalk
codeena
  • Last login:December 03, 2023, 06:23:54 pm
  • This site is cool
« Reply #3 on: November 28, 2021, 08:55:13 pm »
Hi Fablog, where do you get the cushions?
fablog
« Reply #4 on: November 30, 2021, 07:29:58 pm »
Hi Codeena, they came with the cabinet.
I went to an auto store and couldn't find a clip with the good dimensions. Where do you find them guys?
« Reply #5 on: December 01, 2021, 03:40:05 pm »
you might have to try a few auto parts stores... these press fit type of clips aren't used much on cars anymore...auto manufacturers have gone to a 2 piece type clip that is releasable, reusable, and less prone to breaking... so these types of press fit clips have fallen out of use and are getting hard to find.
the new style clips would work and look pretty similar once installed... they are measured by the hole they insert into....basically what you want to do is measure your hole... say it's 8mm... you'd look for an 8mm clip. here is a link to a whole pack of different sizes and styles that also shows what size they are. maybe you could see if one of those might work.
https://www.amazon.ca/EZYKOO-Retainer-BumpersCar-Replacement-HondaAccordNissan/dp/B07HD1BZ3X?th=1
an idea anyway.
fablog
« Reply #6 on: December 01, 2021, 06:04:29 pm »
I think you're right. It's too hard to find exactly the same model. It will be much cheaper to change for a press fit type with the right dimensions. Thanks!
« Last Edit: December 01, 2021, 07:40:16 pm by fablog »
codeena
  • This site is cool
« Reply #7 on: December 13, 2021, 04:38:34 pm »
Hey fablog, are these what you were looking for?
https://www.arcadeartshop.com/product-tag/280-k02529-wx/
fablog
« Reply #8 on: December 13, 2021, 11:36:47 pm »
Hi Codeena, yeah that's them. I know this website but it's too expensive for a shipping to Canada. I may have find a very similar model in Amazon. I hope it works
https://www.amazon.ca/dp/B06W5QNGS5/ref=cm_sw_r_awdo_navT_g_VTN77Y608WPA70P6AZG1
« Last Edit: December 13, 2021, 11:40:15 pm by fablog »
