Author Topic: Problem with disappearing MAME config file when I add analog joycodes  (Read 2649 times)
jimmer
  • Last login:February 17, 2025, 02:48:38 pm
  • I want to play Defender like at the arcade.
It's my first time with a U360, I'm using it in analog mode on a Sinistar panel.
The problem I'm having is that the default.cfg file with the default key allocations keep going blank. It happens when I put joycode codes like below into it
            <port type="P1_BUTTON1">
                <newseq type="standard">
                    KEYCODE_ENTER OR JOYCODE_1_BUTTON5
                </newseq>
            </port>
And it goes blank after playing 2 non-analog games WITHOUT the U360 plugged in. Eg I play Pengo and Qix and then when I go back to Pengo the keys have all reset to default (Ctrl,ALT, etc)
Anyone seen or heard of this problem before?
Any ideas ?
It's MAME 0171.
I'm working on segregating the analog games into a separate MAME folder so they don't interfere with the main games. But I expect to  have the same problems there if the games are run without the U360 being plugged in.
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
Robbbert
  • Last login:March 03, 2026, 11:30:09 pm
Re: Problem with disappearing MAME config file when I add analog joycodes
« Reply #1 on: October 19, 2021, 11:01:58 pm »
It's normal. If you unplug your joystick or controller, the MAME settings attached to it will vanish - and they won't come back.
The usual solution is to make your changes, exit MAME, then make default.cfg read-only.
jimmer
« Reply #2 on: October 21, 2021, 07:04:54 am »
Thanks. It's strange that I didn't know this was a thing, maybe I read it years ago and then forgot because it never cropped up on my system.
Vocalitus
  • Last login:October 25, 2021, 06:16:58 pm
« Reply #3 on: October 21, 2021, 06:42:13 pm »
Mamedevs like to mess with us from time to time.  You get used to it.
