Author Topic: 4P Control Panel Logistics  (Read 3549 times)
FrizzleFried
    • Idaho Garagecade
« on: August 08, 2021, 12:16:54 pm »
OK... so I picked up an NBA Jam conversion that was originally a TMNT.  It even came with the TMNT PCB.  Arcade karma demanded that I rescue bland conversion and bring it back to the ultimate cheezy 1980's TMNT standards.  So I did...
Of course I left it a 3-button layout (plus start) which differs from the TMNT stock 2 button layout (sans start)... as I was going to house both the original TMNT PCB (for that Arcade Karma!) as well as an ARpiCADE MAME setup.
I am now down to setting up the control panel and I've yet to decide how I am going to handle this.
All/most 4P Konami games have a layout like this:
P1 - P2 - P3 - P4
... with the location of where you play determined by the 4 different coin slots.  Input a signal at Coin 1 and P1 lights up,  Coin 2 and P2 is ready to rock,  etc...
This is how I currently have the setup running as that is how the original TMNT is wired...
HOWEVER... on non-Konami and/or games that simply don't use the coin slots to determine location... I'm stuck playing P1 way over on the left!
For those games I'd like to run a P3 - P1 - P2 - P4 setup.
NOW... the question becomes... which is a bigger pain in the butt to go through the games of to set up the controls custom?
Anyone have this answer?   I'm still leaning keeping it P1 - P2 - P3 - P4 just to keep it compatible with the TMNT PCB "stock" (which won't be used though)... but I'm open to changing my mind.
Anyone?
  • Last login:Today at 07:50:29 pm
Re: 4P Control Panel Logistics
« Reply #1 on: August 08, 2021, 01:06:43 pm »
There are far more 2P games than 4P games, so it makes sense to set the MAME defaults to P3 - P1 - P2 - P4 then go into the 4P games and remap the P1 through P3 inputs in those games to P1 - P2 - P3 - P4.
EDIT: I know you already know this, Frizz, but for readers who don't -- there's a potential overlap (highlighted in yellow) between the MAME defaults and IPac4 defaults.
- Anyone with more than 4 buttons for P1 and P2 will have to reprogram the IPac and map P2B5, P2B6, etc. in MAME's "Input (general)" menu.
« Last Edit: August 08, 2021, 01:37:51 pm by PL1 »
FrizzleFried
    • Idaho Garagecade
« Reply #2 on: August 08, 2021, 02:42:18 pm »
This is a dedicated 3P/4P cabinet.   I already have a 2P MAME cabinet.
So I am only really concerned with 3P and 4P games...
Which also eliminates any issue with buttons, etc...
« Reply #3 on: August 08, 2021, 03:16:06 pm »
Since you're not including 2P games, it makes sense to do P1 - P2 - P3 - P4 as defaults and remap the games where you don't want to be "stuck playing P1 way over on the left".   :cheers:
« Reply #4 on: August 08, 2021, 03:34:43 pm »
The other option to consider is mapping the 4P versions of the 4P games (tmnt, simpsons, etc.) as P1 - P2 - P3 - P4 for three or four player gaming and mapping a 2P version of the 4P games (tmnt2po, simpsons2p, etc.) as XX - P1 - P2 - XX for one or two player gaming.   ;D
KenToad
  • Last login:Today at 02:35:49 pm
  • Flap Flap Flap
« Reply #5 on: August 08, 2021, 05:03:59 pm »
I mapped my 4 player control panel defaults as P4 - P1 - P2 - P3, because that makes all the 2 and 3 player games in the correct orientation and all I had to do was remap the 4 player games. I've never understood putting Player 3 all the way on the left. Can anyone explain the rationale of that to me, because it seems to get repeated a lot?
« Reply #6 on: August 08, 2021, 05:47:43 pm »
That makes sense for 2P and 3P games.   :cheers:
I think the reasoning process went something like this.
1. First group:  P1 and P2 get the middle positions because most games are two player.
2. Second group:  P3 and P4 get the outer positions because less games are three or four player.
3. Order within each group:  Player numbers are arranged in increasing order from left to right.
Applying those three rules, you end up with this pattern.
First group
- P1 center-left
- P2 center-right
Second group
- P3 outer-left
- P4 outer-right
FrizzleFried
    • Idaho Garagecade
« Reply #7 on: August 08, 2021, 06:21:31 pm »
That's a good idea as you're right... it would eliminate one spot to have to re-map.
As for the rationale,  I can tell you my OCD kicks in when you say P4-P1-P2-P3...
