Author Topic: Disabling search function in mame?  (Read 5189 times)
peterpiper70
  • Last login:November 05, 2025, 02:59:07 am
« on: August 06, 2021, 09:41:45 am »
I have a Mame machine which has two joysticks and respective buttoms all mapped as keyboard keys. I have changed setting in Mame to work correspondingly.
Problem is when on the Mame front screen if a button or joystick is moved/pressed mame sees it as a letter and changes the list to that letter only via the search function!!
Not sure ive explained this very well but its best I can do
Any one know how to disbale that serach function at the top above the favourites/Export list/show DATs icons?
Regards
Pete
Vocalitus
  • Last login:October 25, 2021, 06:16:58 pm
Re: Disabling search function in mame?
« Reply #1 on: August 06, 2021, 07:11:31 pm »
I had the same problem and it is quite infuriating especially when you are wanting a certain set to use, and wanted to do the very same thing by disabling the interface.
I just moved to Launchbox and put the Mame binary of the set I was wanting to use and pointed the front end to it.  Its free and there are plenty of tuts online,
Launchvox is free and works but not entirely painless...
peterpiper70
« Reply #2 on: August 07, 2021, 07:43:13 am »
Thanks for you response Ill give that a try
Regards
Pete
