Author Topic: GroovyArcade live: can't use 15khz res on CRT TV via laptop VGA  (Read 2944 times)
robsmashed
  • Last login:August 17, 2021, 10:24:54 am
Hello everyone, I'm trying to use a 15khz CRT TV hooked up to my laptop VGA with GroovyArcade
None of the live cd start options correctly feed 15khz to my TV, its output is identified by X as "DP1"
I tried to manually edit the video launch option, replacing it with "video=DP1:640x480ec", but with no success
Thank you
« Last Edit: July 27, 2021, 06:19:55 pm by robsmashed »
Substring
  • Last login:Yesterday at 04:59:45 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
Re: GroovyArcade live: can't use 15khz res on CRT TV on laptop VGA
« Reply #1 on: July 27, 2021, 05:35:26 pm »
Which version are you using ? The old legacy and unmaintained one ? Or the collaborative one ?
robsmashed
« Reply #2 on: July 27, 2021, 06:18:56 pm »
The old Legacy I guess, it's the one that is sticked in this board. 2020.04.08
Substring
Re: GroovyArcade live: can't use 15khz res on CRT TV via laptop VGA
« Reply #3 on: July 28, 2021, 05:38:23 am »
You shouldn't use it if you want some support, better switch to mine
