Author Topic: Hantarex Polo 25 horizontal adjustment  (Read 3084 times)
tdmame
  • Last login:August 02, 2024, 01:33:42 am
« on: July 24, 2021, 06:01:28 pm »
I had the chassis rebuilt and dialed in for NBA Hangtime. I recently installed an Arpicade board and the horizontal needs adjusted (not resized). I'm wondering if the adjustment is on the actual monitor or the remote board? Thanks.
MK3FAN
Re: Hantarex Polo 25 horizontal adjustment
« Reply #1 on: July 26, 2021, 03:58:45 pm »
Your post is contradictory. You need it adjusted and not resized? You mean position or width? Width control is here. The position is on the remote board and should be labeled ‘H.Phase.’
« Last Edit: July 26, 2021, 04:02:08 pm by MK3FAN »
princess prin prin
  • Last login:Yesterday at 02:33:46 pm
  • intrinsically safe
« Reply #2 on: July 27, 2021, 03:27:01 am »
Both position (H. PHASE) and size (H. AMP) are on the remote board. The coil should not be touched.
Ropi Jo
  • Last login:January 18, 2026, 05:05:12 pm
« Reply #3 on: July 27, 2021, 05:36:05 pm »
Hey princess... as you appear to know this chassis well can you advise on the V-Pos in this thead...http://forum.arcadecontrols.com/index.php/topic,165384.0.html
tdmame
« Reply #4 on: August 02, 2021, 12:13:38 pm »
Thank you!
