Author Topic: Arcade 1up - UPDATE TRON, and Marvel vs Capcom Cocktail Table  (Read 16328 times)
negative1
  • Last login:February 14, 2026, 09:59:57 am
coming this fall
https://www.chapters.indigo.ca/en-ca/home/search/?keywords=arcade1up
cocktail table:
https://www.chapters.indigo.ca/en-ca/electronics/arcade1up-marvel-vs-capcom-head/1220000270671-item.html?ikwid=arcade1up&ikwsec=Home&ikwidx=7#algoliaQueryId=602bc92d922ddc9f17913d03f59d5721
Get ready to punch, kick, fly, blast, claw, and oh-so-many-more powers packed into this easily assembled head-to-head table. A phenomenal selection of uncanny Marvel x Capcom titles awaits you: X-Men: Children of the Atom™, Marvel Super Heroes™, The Punisher™, X-Men vs Street Fighter™, Marvel Super Heroes vs Street Fighter™, Marvel vs Capcom™, X-Men: Mutant Apocalypse™, and Marvel Super Heroes: War of the Gems™. Switch up games at will, will the on-screen navigation. Fight opponents, or fight together! Your table is ready…it’s the Marvel x Capcom Head-to-Head from Arcade1Up. 1 table, 2 players, 8 games, endless fun! Specifications: ∙ Age Grading 14+ ∙ Classic Gaming Table Design ∙ Original Gameplay ∙ 8 Games in 1 ∙ 17" Color LCD Screen ∙ Two Control Panels ∙ 1 Speakers on each side ∙ 2 Clear Deck Protectors ∙ Clear Protective Top Surface ∙ Real Feel Arcade Controls ∙ Easy Assembly ∙ Adjustable Volume ∙ On-Screen Game Selection Menu ∙ Plugs into an AC outlet ∙ Easy Assembly ∙ By Tastemakers, LLC ∙ Fully Licensed
Tron:
https://www.chapters.indigo.ca/en-ca/electronics/arcade1up-tron-bundle-with-riser/195570001899-item.html?ikwid=arcade1up&ikwsec=Home&ikwidx=2#algoliaQueryId=602bc92d922ddc9f17913d03f59d5721
The Arcade1Up Tron™ home arcade cabinet stays true to what made the game such a draw in 1982, right down to its signature inner lit blue joystick. Also included is the marquee game’s sequel, Discs of Tron™. With its beautifully vibrant cabinet artwork, along with matching riser, stool, and crisp display graphics, the Arcade1Up Tron™ home arcade cabinet is an icon of ‘80s culture, and a stunning addition to your home.
Specifications: • Custom Shaped “Cabinet “ Design • 2 games in 1 • Custom Riser • Light-up Marquee • Light-up Deck Protector • Light-up Flight Stick • Blacklight Effects • Weight: 82lbs. • Real-Feel Arcade Controls • Coinless operation • Adjustable Variable Volume • Anti-Tip Over Strap • On-Screen Game Selections • In Game Settings Menu • Plugs into and AC outlet • Easy Assembly • By Tastemakers, LLC • Fully Licensed Stool Specifications: • Adjustable arcade stool with extending legs • Height adjusts from 21.5” to 29.5” • Chrome-plated steel frame • High-density foam padding
later
-1
Vocalitus
  • Last login:October 25, 2021, 06:16:58 pm
Re: Arcade 1up - UPDATE TRON, and Marvel vs Capcom Cocktail Table
« Reply #1 on: July 28, 2021, 11:24:31 pm »
Where is the push/pull spinner for DOT?
negative1
« Reply #2 on: September 10, 2021, 10:59:44 pm »
update on tron and t2:
later
-1
Vocalitus
« Reply #3 on: September 11, 2021, 05:58:56 pm »
What do you bet that the DOT will not require a push/pull spinner as they will remove those levels from the game.
negative1
« Reply #4 on: October 07, 2021, 09:46:23 am »
possible tron pre-order
later
-1
negative1
« Reply #5 on: October 07, 2021, 10:58:30 am »
pictures indicate its there.
why would they remove that.
later
-1
Vocalitus
« Reply #6 on: October 09, 2021, 12:56:34 am »
later
-1
Looks like the old asteroids spinner to me.
negative1
« Reply #7 on: October 11, 2021, 09:27:22 am »
later
-1
they got rid of that a year ago.
later
-1
negative1
« Reply #8 on: November 25, 2021, 02:47:43 pm »
review and unboxing of TRON:
later
-1
negative1
« Reply #9 on: November 25, 2021, 03:12:41 pm »
Size of TRON compared to other cabinets:
later
-1
« Reply #10 on: December 05, 2021, 01:08:38 am »
That's a good looking cab
negative1
« Reply #11 on: January 30, 2022, 07:25:13 pm »
updated GRS tron joystick and spinner for discs of tron.
also comes with balltop joystick
later
-1
