Author Topic: help with noob freecad problem  (Read 9115 times)
danny_galaga
  • Last login:February 16, 2026, 07:16:44 pm
    • dans cocktail lounge
« on: July 03, 2021, 01:11:40 am »
See screenshot. I created a clone of a curved line, ran it parallel to the original and a vertical line intersects it. I want to join the vertical at intersection and remove the leftover bits. It's probably really simple but because I find it hard to get a handle on the nomenclature I don't know what to search for.
Re: help with noob freecad problem
« Reply #1 on: July 03, 2021, 07:46:28 pm »
CAD and 3D programs generally share common mechanisms for design.  Where two 'lines' join is called a vertex.  Multiple vertex are referred to as vertices.  A vertex or vertices are objects that can be added to a line/spline/segment to subdivide it and or add connection points.  I don't use freecad but the concepts will be similar. To join the two lines at the intersection:
Add vertices to both lines at the intersecting point, weld the vertices together and delete the unwanted segments.
danny_galaga
« Reply #2 on: July 07, 2021, 09:59:05 pm »
Thankyou! Cutting and pasting that into my CAD notes do I don't forget ☺️
    • GroovyGameGear.com
« Reply #3 on: July 08, 2021, 08:36:04 am »
Not sure I understand correctly, but if I do, it's a very simple operation and present in most CAD software.
Check to see if this is what you are after:
Trimming
danny_galaga
« Reply #4 on: July 13, 2021, 10:00:07 pm »
Thanks guys. I will check tonight but that curved line I made with the b spline tool. I think I may have read somewhere that freecad has some issues with that function.
« Reply #5 on: July 14, 2021, 01:08:01 pm »
According to that page, the B-spline limitation only affects v0.18 and below.  If it doesn't work, I'd try the latest version and see if it has been fixed.
danny_galaga
« Reply #6 on: August 16, 2021, 07:04:21 am »
definitely something to do with B spline. If I create simple overlapping lines in a test sketch it works fine. see pics
