Author Topic: PDF conversion help!  (Read 6472 times)
Dizydawg
  • Last login:August 04, 2021, 02:09:19 pm
« on: June 29, 2021, 05:56:09 pm »
I have a pdf template of bartop arcade sides and control panel. My question is how would i convert to psd keeping orginal size or convert it to png at 300dpi keeping original size? I want to create artwork for it.
lilshawn
  • Last login:February 03, 2026, 06:10:43 pm
Re: PDF conversion help!
« Reply #1 on: June 29, 2021, 07:06:26 pm »
open the pdf in photoshop?? save as png or psd??
i'm not sure the issue here?
most every program can open most every other programs files these days.
« Reply #2 on: June 30, 2021, 01:30:18 pm »
Should be able to export it using illustrator, if you have that. Once opened in illustrator, go to File > Export > Export as... > then choose PNG in the file type dropdown. Once you have the file location and name selected, it will pull up an options screen where you can select the the resolution. Choose 300 PPI and you should be set.
