Author Topic: could a dying CRT be dangerous?  (Read 2379 times)
ericball
  • Last login:March 13, 2025, 11:01:47 am
« on: June 21, 2021, 01:21:45 pm »
Many years ago I squeezed a decased IBM P200 (19.1" viewable, 1600 x 1280 at 60 Hz) into the Tempest cabinet I salvaged.  While I never 100% completed the project, I've been using it to process MAME ROMsets.  But it looks like the monitor is dying:
  • top (actually left side) has pincushion distortion
  • the screen extends off the bottom (actually right side), might have some distortion too
  • occasionally & randomly the screen flickers
Given the monitor is ~15 years old, I suspect some of the capacitors etc are going.  However the flickering has me a little worried that something could be arcing (although I don't hear or smell anything) which would be a potential fire hazard.
Yes, I probably could / should replace it with an LCD.  (I even have a spare Dell 2007 which has similar specs).  However, the look of a CRT is significantly closer to the original color vector monitor and that beast was a pain to get in the cabinet so will probably be even more difficult to get out.
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25% (discarded)
2004 Tempest cabinet & CP > 75% (sold)
2021 Vertical Bartop - in progress > 80%, 100% functional (sleeping)
bobbyb13
Re: could a dying CRT be dangerous?
« Reply #1 on: June 21, 2021, 06:28:00 pm »
Run it in a dark room and look for a fireworks show!
If it isn't arcing due to anode wire insulation problems then I can't imagine it being dangerous unless you mess with the high voltage stuff without discharging it properly.
Definitely sounds like it needs some capacitor work though.
