Author Topic: Vents or fans? (Pc in stand-up cabinet)  (Read 12472 times)
Re: Vents or fans? (Pc in stand-up cabinet)
« Reply #40 on: July 04, 2021, 10:21:10 am »
Computer/electronic equipment works perfectly fine at pretty high temperatures for VERY long periods of time.
If you think 90C is normal operating temps I hope you haven't been in IT long.
Marsupial
  • Last login:April 17, 2024, 09:00:56 pm
  • I am teh Mars!
« Reply #41 on: July 04, 2021, 10:26:14 am »
I try to keep my CPU from reaching 60.
Current temps show a stable 45, with the glass off. I think the hot air comes from my monitor. If anything, I need to exhaust air from the top to avoid it getting under, to the pc area.
I have a grill cover in the mail, and will put a low speed fan on it to help with exhaust. Should work well in my case.
« Last Edit: July 04, 2021, 01:16:07 pm by Marsupial »
-Mars
TOMMYGUN
  • Last login:May 20, 2025, 02:45:11 pm
  • When the time comes you will know
« Reply #42 on: July 12, 2021, 11:57:26 am »
Though it is better to blow in cool air then to exhaust warm air,
you would think it is the same but in the overclocking community i always heard that it is better to pressurize then to suck air out,
for better reach of the cool air everywhere, i think.
Also if you suck air out you will hear the fan more then if you blow in.
« Last Edit: July 12, 2021, 12:07:59 pm by TOMMYGUN »
