Author Topic: MAME board settings interfering with gameplay  (Read 3721 times)
eezeetee
  • Last login:February 01, 2023, 09:17:15 pm
« on: June 18, 2021, 08:48:50 pm »
Something has gotten messed up with my MAME setup. For some reason the arcade stick seems to now adjust the setting of MAME, so when playing there is a line at the bottom of the screen for master volume, screen width, horizontal adjust, etc.
Any idea how I can turn this off or what button it may be?
Note: This is for MAME .230 . I couldn't find the right area here to post, so chose Groovy Mame
  • Last login:Today at 05:45:08 am
Re: MAME board settings interfering with gameplay
« Reply #1 on: June 18, 2021, 10:41:24 pm »
You've triggered the On Screen Display.
- Press the ` key (unshifted ~ key, upper left on your keyboard) to turn it on/off. (default setting)
- It's just above the TAB key, so you probably fat-fingered it when opening/closing the MAME menu system.
If not and you've accidently changed the default key, open the MAME menu system and go to the Input General menu.
- On Screen Display is the first entry.
Moved to Main since this isn't related to GroovyMAME.   ;D
eezeetee
« Reply #2 on: June 18, 2021, 11:08:55 pm »
PL1 enters the chat and solves the problem.
Thanks for the tip, i'll give it a try.
Appreciate the post move too.
