Author Topic: Pitfall Cocktail need some help  (Read 9318 times)
bcgamer
  • Last login:September 30, 2021, 02:33:37 pm
« on: June 05, 2021, 05:54:23 pm »
Build a few mame machines but would like to keep this mainly OG
1.  Monitor working fine
2. Sounds good
Takes quarters and registers
3.  Game board is messed up a bit, players don’t show up etc. Sounds work etc , everything but main gameplay. Right now it’s a Pitfall Lost Caverns pcb
What I want to do.
1.  Is there a way to bypass this board and get a jamma 60 in 1 made for cocktail games? I want to keep the OG guts etc and be able to bypass the old board.
Is this even a jamma connection on this board? They seem to look a bit different ... pics attached.
Any help would be great, I’m fine With most repairs but would like a bunch of options for games , cocktail specific hopefully, and not gut this thing.
Thanks in advance for any help
bcgamer
Re: Pitfall Cocktail need some help
« Reply #1 on: June 05, 2021, 06:02:25 pm »
I counted 22 pins and I’m guessing this is from around mid 80’s so jamma not an actual thing yet?
bcgamer
« Reply #2 on: June 05, 2021, 06:03:26 pm »
The unit
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« Reply #3 on: June 05, 2021, 08:08:31 pm »
this is the  only arcade pitfall that I ran across...
https://www.arcade-museum.com/game_detail.php?game_id=9036
Can we get a better pic of the pcb?
bcgamer
« Reply #4 on: June 05, 2021, 09:25:24 pm »
Here’s one
bcgamer
« Reply #5 on: June 05, 2021, 09:27:34 pm »
Another , do t know how to describe it , a “dual pcb”
Pitfall 2 - the lost caverns
bcgamer
« Reply #6 on: June 05, 2021, 09:31:21 pm »
But anyways I want to keep the guys but bypass this pcb
Is there any product to convert from 22pin that I have to Jamma Standard?
bcgamer
« Reply #7 on: June 05, 2021, 09:32:55 pm »
One more
  • Last login:Today at 07:17:48 am
« Reply #8 on: June 05, 2021, 10:09:40 pm »
Zebidee
  • Last login:February 07, 2026, 01:57:20 am
« Reply #9 on: June 05, 2021, 10:38:44 pm »
https://www.ebay.com/itm/223713963426
PBJ I understand that they want to do the *opposite* of that. They want to run a JAMMA PCB on their unaltered pitfall cab (not run a Pitfall PCB on a JAMMA cab).
BCgamer, You need to make an adaptor "loom" to go from 22-pin to 28-pin JAMMA standard. I say "make" rather than "buy" because you probably won't be able to buy one. It isn't difficult and would probably take you a couple of hours of soldering. You also might be able to get someone to custom make it for you.
Go online, grab 2 things: a JAMMA harness
https://www.ebay.com/itm/192497131511?hash=item2cd1b91ff7:g:ScAAAOSwPoZavnj3
and some 28-pin JAMMA finger boards
https://www.ebay.com/itm/172121505038?hash=item28133dbd0e:g:uRwAAOSwaA5WiUaO
Now, you'll need to reduce the 28 pin finger board to 22 pins. Carefully mark and score along line with a craft knife to snap off (or cut off) the extra 6 pins. You might screw this up first time, so make sure you have multiple fingers to work with. You might be able to find 22 pin fingers, but that will be more difficult and might cost you more. Anyway, I'll leave that to you.
Now you can chop back the JAMMA harness wires and solder them directly to the 22 pin finger.
It is just soldering-by-numbers from here. Follow the original cab harness and standard pinouts as your guide.
The JAMMA pinouts are everywhere online. Here is a pinout for Pitfall II:
https://www.arcade-museum.com/pinouts-game/9036.html
« Reply #10 on: June 05, 2021, 11:47:45 pm »
What he needs to do is convert that cabinet to jamma and then buy that adapter to run his original board.
bcgamer
« Reply #11 on: June 06, 2021, 09:46:01 am »
DUDE thank you!!!
