Author Topic: GroovyArcade on a laptop with CRT in vga port  (Read 2653 times)
NinjaGumby
  • Last login:June 11, 2021, 06:42:20 am
« on: June 01, 2021, 08:47:14 am »
I tried to install GroovyArcade on a laptop (ati HD 6500) with a 15khz monitor hooked to the vga port, but the monitor was never recognized.
Is this scenario supposed to work?
I did finish the install thinking it could be setup after, but after reading more I saw that it needs to be done in the initial setup.
  • Last login:Today at 04:51:39 am
Re: GroovyArcade on a laptop with CRT in vga port
« Reply #1 on: June 01, 2021, 11:09:13 am »
Try disabling the laptop's lcd (lvds) output from the boot menu before installing. This should force the output through the vga. This shouldn't be required, but I'd give it a try.
