Author Topic: Microswitch adapter for the Namco GunCon lightgun  (Read 4966 times)
ebvetle
  • Last login:June 11, 2025, 11:32:41 am
« on: May 27, 2021, 02:42:46 am »
Hello everyone.
I've recently purchased a PSX lot which included a "non working" lightgun.
It has several signs of a very choppy attempt to be repaired, so the trigger is totally wasted.
I've found this piece at thingiverse, which seems to fit a standard microswitch to align with the trigger.
I'll give it a try and let you know just in case you are in same position as me or maybe want to give a more arcade touch to the home market guns.
https://www.thingiverse.com/thing:4864970
Cheers!
