Author Topic: T-Molding Question  (Read 6474 times)
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
T-Molding Question
« on: February 25, 2004, 01:42:51 pm »
Hi all,
Anyone have any ideas on how to install T-Molding around a 90 degree angle? When I try to install it, the molding binds up (i.e., the part that goes in the slot).
Thanks,
Garry
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
PacManFan
  • Last login:December 06, 2005, 12:18:56 pm
    • Kymaera Home Page
Re:T-Molding Question
« Reply #1 on: February 25, 2004, 01:47:07 pm »
What you will have to do it make cuts every 1/4" to 1/8" in the back spine of the T-Moulding with an x-acto knife so it will follow a curve. This is what I did for my cab and control panel, and It works great.
You may also consider filling the grove with a little hot-glue right before you put the t-moulding in, that way it'll stay in better.
Hope this helps,
-PacManFan
All Hail Smezznar! The Giant purple centipede of Omnicron 5. Regail him with your odiferous offerings of onion powder!
Jabba
  • D-Hutt
« Reply #2 on: February 25, 2004, 02:10:01 pm »
Hope this helps,
-PacManFan
Do I just make a simple cut or do I need to cut out a notch (i.e., 1/8", 1/4", etc). Do you have any pictures?
Thanks,
Garry
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
« Reply #3 on: February 25, 2004, 02:56:16 pm »
Cut a notch. Take the molding and bend it at a 90 degree angle. If you cut you're notch big enough it won't bunch up or give you any problems. Really simple.
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #4 on: February 25, 2004, 05:16:30 pm »
FYI: For right angles I cut about 1 inch of the spine out and it worked great.
saint ganked my avatar.
NoOne=NBA=
« Reply #5 on: February 25, 2004, 06:54:33 pm »
I assume you are meaning that you are turning it around a square corner?
If so, the best way to do that is to cut a 90 degree V out of the spine of it, with the point of the V centered on the corner.
That allows the spine part to meet perfectly inside the groove on the corner.
I agree with PacManFan about gluing the joint.
If it's going to be in a "high traffic area" like the edges of a CP or something, I wouldn't use hot glue though, I'd use epoxy.
Hot glue doesn't really stick to anything (especially plastics and vinyls), and will let it pull back out too easily.
If you get the 90 second setting epoxy, you can hold the pieces in place by hand.
The 5-minute kind gives you a little more working time, but you'll probably want to hold the pieces in place with a bar clamp until they set.
