Author Topic: Will this GPU suffice?  (Read 3073 times)
morton
« on: May 06, 2021, 12:00:45 pm »
Hi all, hope everyone is keeping alright.
I am in the process of finally piecing together a GM rig, and have this GPU I was given:
Vapour X Radeon HD 5870
Presumably this will work in conjunction with a JPac to get me some 15khz action yes? The DVI ports aren't labeled DVI-A for sanalog that I can see and there isn't any info I could find easily to tell me whether this card would work. I know not all Radeon hD cards will do what I need it to, but hopefully I just need a conversion connector and be off to the races. Any help is appreciated. Thanks.
psakhis
Re: Will this GPU suffice?
« Reply #1 on: May 06, 2021, 01:55:18 pm »
Hi,
Initially you don't need jpac 15khz bypass (although you can continue using it for the controls); with crtemudriver on HD5870 you get 15khz natively.
I don't know what happens if you connect HD5870 at 15khz to jpac...seems overkill but maybe works as well.
Zebidee
  • Last login:Yesterday at 10:41:29 pm
« Reply #2 on: May 06, 2021, 03:53:13 pm »
HD5870 is on the list of compatible cards.
You need to say what video heads it has - DVI-I, DVI-D, VGA etc. If you don't know a link or a pic would be enough. I imagine a card of that vintage likely has some analogue outputs.
For the JPAC, you may or may not need it - What are you going to output to? TV? Arcade monitor? Something else?
morton
« Reply #3 on: May 06, 2021, 05:23:34 pm »
I was going to install it into a Jamma cabinet.
As for the card... There's a Display Port, an HDMI, and two DVI ports not indicating if analogue or digital. The card originally came with a DVI to VGA adapter. I don't have one at the moment. I will need to order one if this will work.
Zebidee
« Reply #4 on: May 06, 2021, 06:36:33 pm »
You will want to run the signals through JPAC to your JAMMA cabinet.
At least one of your DVI ports must be DVI-I (has analogue). You can tell which one because on one end there will be analogue outputs. Looks like a double division symbol welded together, like a line/bar with 2 pins on top and 2 pins on bottom. Female side usually has a cross with holes in each quadrant.
Here is an article explaining how to work out which is what:
https://www.ooberpad.com/blogs/audio-video-tips/what-is-the-difference-between-dvi-i-and-dvi-d
You'll need a DVI-VGA adapter. They are cheap.
