Author Topic: Swap Nanao MS8-26SU for WG 27K7502?  (Read 1948 times)
Schlitzman
  • Last login:April 27, 2021, 12:03:30 am
« on: April 26, 2021, 01:55:04 pm »
Hi all --
I have a Sega Virtua Cop 2 (Sega Model 2) with a fuzzy, dim monitor that will not register the guns.
I acquired a Wells-Gardner 27K7502.
Will it work with the game?
Any advice in terms of making the swap?
I have no idea yet if the WG monitor is working or not. I plan on recapping it and inspecting it thoroughly before attempting the swap.
Ethan
grantspain
Re: Swap Nanao MS8-26SU for WG 27K7502?
« Reply #1 on: April 27, 2021, 05:35:58 am »
unless the nanao tube is bad i would suggest a service for the chassis, most likely there are some leaky capacitors that could do with replacing
I would imagine you could find someone to service the chassis at a reasonable price or do it yourself if you have some soldering skills
