Author Topic: Default knob for TurboTwist 2 spinner?  (Read 1355 times)
SRGilbert
  • Last login:October 09, 2025, 04:14:35 pm
« on: April 20, 2021, 10:34:28 am »
Can anyone post a picture and dimensions of the default knob that is included with the TurboTwist 2 spinner?  The GGG description says "Stylish Red, shiny aluminum-shell" but all the photos show a black knob.
Is the red knob solid aluminum?  I might not be able to use the ESC (X-Arcade 2 player) due to short depth of the box, but I'm concerned about spin.
Also, Randy says "If operation as a spinner is desired and a lightweight knob is to be used, it is strongly recommended that the optional Energy Storage Cylinder (ESC) is purchased." but doesn't say which knobs are considered "lightweight"?
« Last Edit: April 20, 2021, 10:40:31 am by SRGilbert »
    • GroovyGameGear.com
Re: Default knob for TurboTwist 2 spinner?
« Reply #1 on: April 20, 2021, 11:44:42 am »
As written, it has an aluminum shell.  It is not a solid aluminum knob.  It is a lightweight knob.
If you have no need for a steering wheel or the Accu-twist feature, and you have limited space below the panel, I highly recommend the TT2 Sci-Winder.
SRGilbert
« Reply #2 on: April 20, 2021, 08:52:45 pm »
Thanks Randy!  I would have gone directly to the source but I know you are a busy guy.
