Author Topic: Why my compiled groovymame 0.229 is 522MB instead of 207MB ?  (Read 2653 times)
fred92
  • Last login:March 03, 2025, 01:45:41 am
« on: March 24, 2021, 12:17:34 pm »
Hello all,
i have compiled groovymame (using msys64 and make)  with this option :
make -j5 subtarget=arcade
and the .exe size is about 522MB.
Is there a way to reduce the size like the 207MB of Calamity's ?
thanks.
Fred.
Edit :
i found UPX, with a simple drag and drop it resized to 298MB...
And you, what do you use ?
thanks.
« Last Edit: March 26, 2021, 05:50:31 am by fred92 »
Substring
  • Last login:Yesterday at 05:15:00 pm
  • Forking GroovyArcade
    • GroovyArcade active fork
Re: Why my compiled groovymame 0.229 is bigger than original ?
« Reply #1 on: March 25, 2021, 05:52:23 am »
I don't remember if the mame exe is stripped, but you should try + don't activate debug symbols + -O2 or -O3 + check dist.mak, it has some interesting flags to use
fred92
Re: Why my compiled groovymame 0.229 is 522MB instead of 207MB ?
« Reply #2 on: March 26, 2021, 05:49:57 am »
thanks you Substring for your answer
i tried this :
make -j5 subtarget=arcade debug=0 strip_symbols=1 PTR64=1 OPTIMIZE=3
(i'm using latest msys64.exe, all is up to date, and GM source)
but same size : 522MB.
i don't understand...
Could someone share his compiling command ?
« Last Edit: March 26, 2021, 06:02:13 am by fred92 »
  • Last login:February 19, 2026, 06:15:36 am
« Reply #3 on: March 26, 2021, 06:59:36 am »
Hi fred92,
Here are the flags I used (before github):
OPTIMIZE=3 SYMLEVEL=1 SYMBOLS=1 STRIP_SYMBOLS=1
However you'll need to start a clean build, otherwise they won't have the result you expect.
fred92
« Reply #4 on: March 26, 2021, 07:50:54 am »
Hi fred92,
Thank you Calamity for your clear answer.
I'll edit this post after trying a fresh new compilation with this command :
make -j5 OPTIMIZE=3 SYMLEVEL=1 SYMBOLS=1 STRIP_SYMBOLS=1
(see you in 1 hour and a half... time it takes to make the job)
Good news, GM is now 287MB  it's betten than at the biggining.
Thank you very much for your answer and for Groovymame software !!
Fred.
« Last Edit: March 26, 2021, 01:42:13 pm by fred92 »
